korda
Posted: Mon Apr 18, 2005 2:42 pm Post subject: sony DA33Es receiver - Protector (Fan) flashing mode |
I have a sony DA33Es receiver and no sound is coming out of the speakers. On the receiver it is flahing protector (fan). Does anyone have any clues on what i need to do or replace?
any input is greatly appreciated.
korda |
Braxton Guest
Posted: Wed Aug 03, 2005 9:30 pm Post subject: FRIED |
| Your power output is fried |
paulfcdx Guest
Posted: Sun Sep 24, 2006 10:00 am Post subject: cheaper solution PROTECT FAN message |
from another forum
The message PROTECT FAN may indicate that there has been fan failure, but it also may be the result of a cold solder joint.
Service Bulletin Document Reference E08912783, dated 11/14/2000, "PROTECT FAN DISPLAYED WHEN POWERED ON - REPOSITIONED D955", addresses one such case.
The SYMPTOMS listed are as follows:
"Protect fan displayed when unit is powered up, pin 70 at IC1201 reading 1.2v found diode stack D955 +5v terminal not feeding through circuit board at solder point.
Repositioned diode and tested unit."
D955 is located in the upper left hand corner of the MAIN BOARD. D955 is the bridge rectifier unit for the +5V REG power supply. Apparently, the problem was caused by a low +5V REG power supply output voltage. |
