rush1
Posted: Mon Apr 18, 2005 4:30 pm Post subject: RCA PKT 195 |
| Im working on a RCA PKT 195 projection tv that has a CTC195 chassis.The promlem was a bad flyback after the part was replaced tv will power up again but takes 2-5 min before i get video,it has h/v and filimate voltage and raster if screen controls are turned up.If tv is powered off and then right back on it still requires the 2-5 min wait before video returns.When video does come on set looks and acts normal ,its just at start up.I really need help with this one |
rush1
Posted: Tue Apr 19, 2005 10:02 pm Post subject: |
| looks like i went over everyones head with this question |
Posted: Thu Apr 21, 2005 10:45 am Post subject: re; RCA 195 |
You didn`t say if the problem is with tuner input or video input ?
does the audio work at start up? try both inputs, if it works on
"video input" then the onboard tuner needs solder work, if both
inputs don`t work then your in for a lot of scope work, did you
resolder the HOT and L4401 (next to HOT) should re-do all the
pins of the HOT driver transformer as well, good luck, Larry E |
Posted: Thu Apr 21, 2005 10:07 pm Post subject: |
| problem is both modes ,video and normal tuner operation.yes there is sound the picture is just dark for 2 to 5 min.Does not seem to be a cold solder joint nor will heating the board makes any difference.I really think i have another componet that has failed and im lost at this point |
chuckie14 Guest
Posted: Thu Mar 30, 2006 2:59 am Post subject: info |
Hello out there anybody have a schematic for a p60812bl, ctc-195a chasis (can't spell today) i realyyyyy need one my wife is about to kill me says that the tv is to big in the living room not to work please hellllpppp i think the power supply went out??????????????????  |
ohmster Guest
Posted: Mon Jun 05, 2006 4:27 am Post subject: |
Still need the manual? I have it as a 200Mb CD iso image. Burn to disk or mount the image with daeom tools (free program). Email:
ohmster at newsguy dot com |
