mijatovic_86
Posted: Mon May 02, 2005 5:34 am Post subject: Grundig CUC 1825 problem |
I have Grundig cuc1825, after replacing procesor SDA 5250, TV won't respond to remonte control !
When i turn on the tv,it shows a LANGUAGE display, but a can't change anything, because in doesn't respond to RC!!
i even replaced eproms, 24c08 and 24c02, bus the problem is still here !!
Does anyone have any idea, or what...................???
the procesor is ok, it isn't a problem |
Jeffouille Guest
Posted: Sun Feb 12, 2006 9:24 pm Post subject: Nearly same problem |
I have got the same tv with the same chassis and I have problems too :
for a long time, the tv switched off after 10 or 15 minutes and now I can't switch it on at all. The tv does not run any more, it keeps stand by mode.
I have opened and looked into the tv, all power components seem good.
How did you do to replace SDA5250 ? Isn't it a component which must be pre-programmed ? Do you know what are the reasons of my problem ?
Thank you for responding. |
madkris
Posted: Fri Mar 03, 2006 6:36 am Post subject: |
| what was the initial problem with this tv set? |
Posted: Thu Oct 11, 2007 2:18 pm Post subject: Re: Nearly same problem |
| Jeffouille wrote: |
2sa1535 Panasonic • SD-9500E Toshiba • 42lm7600-ta 42lm7610-tb chassis lb22e mf • VM0701012CE A NV-GS230EG panasonic • Panel SAMSUNG SDI S50HW-YD01 0 [DS] . Va • gp160-05 CANON • Toshiba CEE068 [SCH] TOSHIBA • DR-5 SERVICE NOTES BOSS • datasheet 1ZC33 • 2sk4033 . Electronic Components Datashee •
