jkf Guest
Posted: Tue May 03, 2005 6:51 pm Post subject: fan won't work |
| I have a Technics sadx1040 receiver and the cooling fan won't work, I tested the fan and it works I am not getting any power. All the fuses I could find are ok. any ideas? |
Posted: Tue Aug 30, 2005 1:49 pm Post subject: |
| i have om of thease amps and it only kiks in when i get it two about half |
Posted: Tue May 23, 2006 4:23 am Post subject: Re: fan won't work |
| jkf wrote: |
I saw someone posted somewhere it only works at >70% volume...
I tried to get power for the fan from the +15 v power rail and it worked fine when it was still apart but I think the wire shorted to ground and zapped the power supply so the unit is mostly dead now, I'm looking for a service manual to fix it with....
The other idea thea should work good is to use a small power supply to run the fan all the time and plug it into the convienience outlet in the back so it only runs when the unit is on... |
Posted: Tue May 23, 2006 5:30 pm Post subject: |
Usually it is driven by a temperature sensor on the heatsink. When it gets hot the fan comes on.  |
gsnoorky Guest
Posted: Fri Jan 15, 2010 12:26 pm Post subject: Bedeviling heat problem. |
I know this post is ancient: Thanks for the info! This receiver runs far hotter than any others I have owned. Currently, I use it in my office with my PC for small 5.1. It helps heat my home in winter--I don't like it in summer, though-it still keeps trucking, even given severe heat issues. I replaced it's fan with a PC fan some time ago--to no avail (I assumed the oem fan was defective). The heatsink doesn't look as good as old school--i.e., before digital and hdmi. I wonder if the fan ever went on. I still have the relatively heavy old fan somewhere, with cut wires. It has three optical-only jacks--no coax spdif. I don't like it as well as the updated Onkyo I own, with assignable spdif (someone sold that to me--probably to get hdmi)--however, the Technics probably didn't cost as much (in real terms). The latter receiver has a large heatsink and runs pretty close to ambient!  |
CRM57R Clarion • CL2560 Hitachi • Panel CMO N156B6-L0B 8 [DS] . Various • 2sc4402 . Electronic Components Datashee • QM16.1L la Philips • DVDR3575H SI 1203420978 Philips • Stereo Clipper 3210 Nordmende • President U536 Unica • DV-525 Pioneer • RF263AE Fast track R1 optimized Samsung •
