skytec Guest
Posted: Thu Aug 14, 2008 8:59 am Post subject: Sony KE-32TS E Low width |
The reported fault initially was a red vertical line on the LHS moving inward as it warmed up with the width reducing slightly. After removing the back cover it now has very low width perminently.
It doesn't appear to have any d/j's and there are no elecs showing signs of distress...can anyone help please |
Posted: Thu Aug 14, 2008 9:09 am Post subject: |
Does it have E/W (pincushion) distortion too or is the width too low with straight edges of the scan?
If there also is signs of E/W distortion, then check the E/W modulator parts (diodes, flyback cap, bridge coil, E/W drive transistor and so on).
In case of no E/W distortion, then check the supply voltage to horizontal output as a first step. |
Posted: Thu Aug 14, 2008 1:24 pm Post subject: |
| No, there's no E-W distortion...this is a plasma tv |
Posted: Thu Aug 14, 2008 3:26 pm Post subject: |
| I'm so sorry...it doesn't have low width, just the low width of the brain that wired it up to a satellite receiver incorrectly set!! However if we can start again...The picture has two vertical lines through the image 3-4 inches from the sides, the left one is red and the right is green, any ideas? |
Posted: Thu Aug 14, 2008 10:50 pm Post subject: |
| One pixel thick? |
Posted: Fri Aug 15, 2008 7:56 am Post subject: |
| yes |
Posted: Fri Aug 15, 2008 8:07 am Post subject: |
| unfortunately it is most likely the plasma panel has failed, old unit, only 32" plasma i have ever seen, sony no longer even make plasmas only lcds. |
