joshc Guest
Posted: Tue Sep 02, 2008 10:17 pm Post subject: American electronics in Germany |
Hello,
I'm an American who has just moved to Germany. I've got a bunch of American electronic equipment. It seems like the only practical thing to do is run the equipment into an American surge protector, the surge protector into a convertor/adaptor, and the convertor/adaptor into the wall.
Three questions:
1. Is there a better solution?
2. Does my solution endanger my equipment?
3. Do I need any particular kind or quality-level of surge protector or convertor/adaptor?
Thanks,
Josh |
Posted: Wed Sep 03, 2008 2:06 am Post subject: Re: American electronics in Germany |
| joshc wrote: |
Hello,
Three questions:
Thanks,
Josh |
By "electronic equipment", if you mean entertainment (TV/video/audio), providing a converter for voltage difference from 220V to 110v is usually not a problem however, video format compatibility IS the problem.
Any television designed for USA, is pretty much useless for reception in Europe & vice versa unless it is specifically designed as a multiformat (very unlikely)
Similar with DVD players due to region coding of media material. Tuner station spacing may also be different which will affect FM reception.... you can google the subject & find much more.
In a nutshell, when moving to/fro overseas, better off leaving home entertainment behind--with an exception of may be Amps/speakers |
Posted: Wed Sep 03, 2008 4:27 am Post subject: |
| 60 hertz vs 50 hertz. Pal vs NTSC. |
Posted: Wed Sep 03, 2008 12:08 pm Post subject: |
The major problem is the mains voltage, 230 V in Europe as related to 110-120 V in the US. This problem is most easily solved by using an 230/115 V transformer, but make sure that it has a large enough power rating. You should use a full transformer rather than an autotransformer, in order to get the 115 V equipment galvanically isolated from the mains. American 115 V equipment does not fulfill the safety rules required for directly powering them from a 230 V mains.
Equipment with switch mode power supplies (most modern electronic equipment) will work equally well on 50 or 60 Hz, but you should be careful with equipment with a mains transformer unless the nameplate expressly states 50/60 Hz. There is a possibility that the core of a transformer that is designed for 60 Hz gets saturated when running on 50 Hz, and this will cause noise from the transformer and possibly overheating.
Also, electromechanical equipment with induction motors will run slower on 50 Hz, that might be a problem in some cases. |
ktd1863 KEC • irls640a Fairchild Semiconductor • Telestar • C115 Motorola • Duet Whirlpool • chassis n82a le32c53 le37c53 le40c53 le4 • D356P/PA AOC • fdn359bn Fairchild Semiconductor • KD-SHX701 SM AIWA • Panel JDI TX76D02VM0BAA 0 [DS] . Various •
