Posted: Sun Sep 14, 2008 5:57 pm Post subject: |
ok, the designation ECB is definitely NOT for FET. let me do some checking & will post back |
Posted: Mon Sep 15, 2008 2:25 am Post subject: |
Mad Professor wrote: | vtech: I know that you wanted a picture of the face transistor, but I just can't get a clear picture of it so did not bother uploading it.
The PCB marking for the transistors are ECB.
Best Regards. |
Update;
Based on your numbers, it appears that the transistors are actually BJT's part# HSD965 & made by a yingyang outfit called; Hi-Sincerity Microelectronic corp. which is the same as 2SD965
Not a high voltage but rather high current transistor in TO92 package which is also applicable for flash circuit.
Keep in mind that in any circuit, transistor failure can easily be caused by another defective componenet such as leaky/shorted cap/coil/etc.
So if it's worth messing with this, make sure to spot check various caps/diodes around the circuit(especially the blue caps) & good luck. |
Mad Professor
Posted: Mon Sep 15, 2008 6:24 am Post subject: |
vtech: Thanks again for your time and support.
I am based in the UK, and have just looked on RS Components UK Ltd and Digikey UK for the two part numbers with no luck.
Now I have two datasheets thanks to you, I can try and cross ref the part numbers to something else I might be able to use.
Best Regards. |
Mad Professor
Posted: Thu Oct 02, 2008 1:10 pm Post subject: |
I have been away from home for a few weeks.
I've been looking around for a HSD965 or 2SD965, The best match I have been able to find so far is a STSA851.
Can anyone tell me if this should do the job?
Thanks for your time. |
Posted: Thu Oct 02, 2008 6:09 pm Post subject: |
Mad Professor wrote: | I have been away from home for a few weeks.
Don't think the gain difference (hfe) matters that much & It should do the job, provided there are no other problems, although pay attention to the difference in package pinouts (EBC)Vs(ECB)---follow it exactly on the board, may have to twist them to match. |
Mad Professor
Posted: Fri Oct 03, 2008 6:24 am Post subject: |
vtech: Thanks again for your time.
I ordered 10 last night from rswww.com last night, albeing well I should get them today.
I will report back with how I got on. |
Mad Professor
Posted: Fri Oct 03, 2008 4:54 pm Post subject: |
I got my new parts this afternoon, Had to twist the two right pins around on each one to get the pin config right, but that was not a problem.
As I was fitting the new parts I spoted that C6 had pufed up and split, How I did not spot this before I don't know.
So I carried on and fitted the 8 STSA851's, and removed C6, I also removed C7 as it is also connect to the same lines as C6.
So I now need to get two caps, but I must admit I don't know how to read this style of cap.
F .27J
PMD 250V |
Mad Professor
Posted: Fri Oct 03, 2008 5:09 pm Post subject: |
I have just had a quick look on the internet for ".27" and it looks like this is a 2uF 5% 250v Cap.
Can someone please confirm this before I go and order some new ones.
Thanks. |
Posted: Fri Oct 03, 2008 5:41 pm Post subject: |
Mad Professor wrote: | I have just had a quick look on the internet for ".27" and it looks like this is a 2uF 5% 250v Cap.
Thanks. |
Is it the two blue caps against each other(looks like siliconed together)--definitely the cause of txistors shorting out.
Value/voltage is definitely critical here;based on your posted numbers,
.27 means>> point-two-seven microfard NOT 2 microfarad
250v is working voltage. Ok to use a higher voltage if 250V not available but keep the mf value.
Similar to this |
Icey Guest
Posted: Mon Oct 13, 2008 1:06 am Post subject: Same problem help please |
basically i have the exact same original problem as you mad professor tv wont turn on from standby, but i am not very techno savy. all these parts are a little daunting. is it likley to be the same faulty parts casuing the problem?if i could definatley solve the problem by buying a whole new power board (as you originally said)i would be happy to do that. how hard would it be to do this? and could somebody point me in the direction of this power board. thankyou |
