leafar
Posted: Thu Oct 02, 2008 11:38 pm Post subject: sony tv |
leafar wrote: | minnie wrote: | Did you try turning up the screen control on the flyback? |
Yes sir, i adjusted the control on the flyback ,the first one the lower section adjustment,it maybe the focus.because when the pic is snowy i adjusted it and it works fine. i think the upper adjustment is for the screen ? if so,i`ll try to adjust it tommorow. i will give you feedback sir later on.
Thank you again for your help. |
Sir minnie ,i adjusted already the screen control on the flyback but still with same problem .any idea sir? |
Posted: Fri Oct 03, 2008 4:34 am Post subject: |
Bad picture tube. |
leafar
Posted: Tue Oct 07, 2008 12:15 am Post subject: sony tv |
Anonymous wrote: | Bad picture tube. |
sir, If it is a bad picture,how come that the TV is working w/o interruption in my viewing for a long period of time without changes in pic or sound .my real problem right now is the tv will not start up on its usual operation,after switched it on i heard a high pitched of sound , relay (1 click),lit is blinking more than 10 blinks then it will start sometimes it took 2-3 min unlike before 10-15 min.Anyway, if is a bad crt i have nothing to do until it is not usable anymore before throwing it to junkshop.
Thanks a lot guys . |
cogil
Posted: Tue Oct 07, 2008 9:13 am Post subject: |
minnie wrote: | True, but I've fixed many Sony's that the crt filaments are lit, set had sound and high voltage but no osd or raster. I'm not saying the vertical ic is bad to cause a hard fault but may have cold solder joints. Could it also be a weak crt, yes. |
As minnie says possibly a weak crt, for which you must have similar to try out and prove faulty. |
leafar
Posted: Wed Oct 08, 2008 12:02 am Post subject: sony tv |
cogil wrote: | minnie wrote: | True, but I've fixed many Sony's that the crt filaments are lit, set had sound and high voltage but no osd or raster. I'm not saying the vertical ic is bad to cause a hard fault but may have cold solder joints. Could it also be a weak crt, yes. |
ok sir thanks a lot for the reply, i will check it again & post my feedback this coming weekend. |
leafar
Posted: Mon Oct 20, 2008 3:21 am Post subject: Re: sony tv |
leafar wrote: | cogil wrote: | minnie wrote: | True, but I've fixed many Sony's that the crt filaments are lit, set had sound and high voltage but no osd or raster. I'm not saying the vertical ic is bad to cause a hard fault but may have cold solder joints. Could it also be a weak crt, yes. |
sir i resoldered all components in the main board including the pcb in CRT tube, the set is working good right now. thank you .. |
cogil
Posted: Mon Oct 20, 2008 3:50 pm Post subject: |
success is always good, and that is ok if the tube wasnt the issue |
2sa1276 Inchange Semiconductor • T-100 Accuphase • LBT-D220 Sony (Bulletin) • Panel CMO V315B3-LN1 2 [DS] . Various • c-2 HEATHKIT • ICFSW11 Sony • Roland GR-300 Service Manual Roland • 22sc5584 2 • STANFORD RESEARCH SYSTEMS SR850 Operatio • CNX82A.W, CNX83A.W, SL5582.W & SL5583.W •
