tanami
Posted: Thu Oct 30, 2008 4:42 pm Post subject: Request for Service Manual for AEG L62800 |
Hello,
Please assist with Service manual for AEG Lavamat 62800 washing machine (PNC - 914 003 173)
Thanks in advance,
Tanami
Posted: Fri Nov 07, 2008 9:29 am Post subject: |
Hello,
As added above, it is a Lavamat 62800 AEG washin machine. I need information how to configure it following main (configured) board replacment.
Any help will be appriciated, thanks
Oren |
z3ratul
Posted: Fri Nov 07, 2008 1:17 pm Post subject: Re: Request for Service Manual for AEG L62800 |
| tanami wrote: |
Hello,
Thanks in advance,
Tanami |
you don`t need service manual for this...you need to know a little electronic ...to check some parts |
tanami
Posted: Fri Nov 07, 2008 1:41 pm Post subject: |
Hello,
I know how to deal with electronics (both HW and SW) but this is not of help as, most likely, I need some hidden codes for being able to configure my machine.
Background:
I am located in Israel but my machine was purchased in the UK. Unfortunalty this specific model (PNC) is not supported in Israel that;s why I failed to locate any local profetional that can support me.
Recently I replaced the main board (configured board EWM100+) as the original one was burned out. Unfortunatly it is not functional altough it was electrobicly installed.
I suceeded to enter electronic test mode by pressing two hidden buttons for ~5 secs while turning the machine on. In this mode you can see all the leds, each button press results in desplaying it's ID on 7-seg. Each main selector change results in it's program code on the 7-seg.
I understand that there is some priocedure to configure the new board to my machine. This is what I am looking for .. I assume it is explaned as part of the service manual ?
Any advice will be much appriciated.
Thanks,
Tanami
olealexa
Posted: Sun Dec 07, 2008 12:22 am Post subject: |
Hello Tanami.
Did you find out of your test mode trouble? It seems like I have run in to exactly the same problem as you did after replacing the main board. My L74560 seems completely dead until I do the combination of pressing two buttons and turn the knob. Then it enters some test mode similar to what you describe. I would really appreciate if you could help me out of this trouble.
Regards
olealexa
| tanami wrote: |
Hello,
Background:
Thanks,
Tanami
tanami
Posted: Sun Dec 07, 2008 6:32 am Post subject: |
Hello olealexa,
Unfortunatly I failed to repair my machine, altough I am quite sure it is related to some hidden setup/procedure and/or wrong ROM code within my new main board. Finally, after two months without a washing machine (family with three childs and a baby) I bought a new machine.
Still,
I'll appriciate if you will keep me updated in case you have any solution as I am keeping the problematic machine.
Regards,
Tanami
| olealexa wrote: |
Hello Tanami.
Regards
olealexa
| tanami wrote: |
Hello,
Background:
Thanks,
Tanami
olealexa
Posted: Sun Dec 07, 2008 8:39 pm Post subject: |
Hi Tanami,
I'll keep you updated. I can however give you some more information right away.
When I ordered my new main board, the repair guy first said that the board had to be programmed in order to work. However, after checking with a colleague, he told me that the main board was shipped pre-programmed. Along with the mainboard, a notice explaining that some IR-interface connector (3-wires) should be left unconnected. I think this IR-connector leads to an IR-diode in the front, being used as an interface with the programming tool. This support the information I got that no programming should be required. It was also said that I had to turn on and the off again to exit a test mode, which I did without any effect
I'll try to call the repair guy tomorrow. Hopefully he is willing to give me a tip or two, taking into account that I bought the main board from him for appr €250.
Regards
olealexa
| tanami wrote: |
Hello olealexa,
Still,
Regards,
Tanami
| olealexa wrote: |
Hello Tanami.
Regards
olealexa
| tanami wrote: |
Hello,
Background:
Thanks,
Tanami
olealexa
Posted: Tue Dec 09, 2008 3:48 pm Post subject: |
Here is an update on my current findings:
I got some inputs from a technician. He told me that after entering the test-mode (by holding two buttons and turn the knob one step clockwise), I should release the buttons and turn the knob: one step counterclock-> one step clockwise -> one step counterclock. This should apparantly make the machine exit the test mode.
Unfortunately, this did no difference at all
Currently I have two theoris:
1) I have wrong software on my board. I am currenlty trying to verify this.
2) The communication between the u-controller on the button/display board and the main board is broken. The test-mode that we both have entered could be a test-mode of the button/display board itself. Buying another buton/display card is not very tempting taking into account that it could be something complety else wrong.
Note that I found a service manual for the EWM 100 plus board used in an electrolux machine. I'll dig up the link again. It could be of some value.
Regards
olealexa |
2sb1203 Sanyo • sc5 lcd panasonic • EN7410 Monitor LCD AOC • 46 Philips • 1973-12 Agilent • DTQ-14P2/P3FCG ecc... Daewoo • [radial thru-hole] 85SLL Series Wincap • ElectroVoice-P1200 pwramp . Various • DebugXMDefs.mesa Sep78 xerox • ® Core™2 Duo Processors on 45-nm process •
