Larbo
Posted: Tue Dec 09, 2008 11:11 pm Post subject: |
I get the little ones, no issue (how about my earlier "helful" instead of helpful!! that's a goodun. |
Posted: Tue Dec 09, 2008 11:24 pm Post subject: |
I call dish network dish dish no work. S video bypasses the tuner. There is no luminance correction. Try composite video or channel 3 through coax. Better yet this is an HD ready set. Get the HD box. The tuner can at least attempt gain correction. |
Posted: Tue Dec 09, 2008 11:30 pm Post subject: |
Try local stations via antenna or cable. |
Larbo
Posted: Tue Dec 09, 2008 11:43 pm Post subject: |
No cable since I have Dish. Outside antenna? Hmmmm. I will see if I can find that coax lead.
Minnie, so there is a history with you and Dish that I am not aware of. Diss'n Dish... has a ring to it. We have had pretty good service from Dish except for the DVR going berzerk occassionally. I will try the composite input. The RF pic really stinks, though. Not going there.
Thanks. |
Posted: Wed Dec 10, 2008 1:35 pm Post subject: Re: edit |
I noticed that too. I've seen the "edit button" during Private Message posts.
FAQ - Under "Posting Issues":
Quote:
How do I edit or delete a post?
Unless you are the board admin or forum moderator you can only edit or delete your own posts. You can edit a post (sometimes for only a limited time after it was made) by clicking the edit button for the relevant post. If someone has already replied to the post, you will find a small piece of text output below the post when you return to the topic that lists the number of times you edited it. This will only appear if no one has replied; it also will not appear if moderators or administrators edit the post (they should leave a message saying what they altered and why). Please note that normal users cannot delete a post once someone has replied. |
Larbo
Posted: Wed Dec 10, 2008 3:08 pm Post subject: |
I had read the FAQ and it at least infers that if logged in, you should be able to edit your own post right after you post it and that is not happening every time (only 2 out of 5 times). Seems pretty random. |
Posted: Wed Dec 10, 2008 3:22 pm Post subject: |
I've ONLY seen the "edit button" when viewing a Private Message I've just posted.
I don't recall EVER seeing one at any point during a regular post.
On a somewhat similar train ... Can you browse through the different pages of "View Unanswered Posts" ? |
Larbo
Posted: Wed Dec 10, 2008 3:37 pm Post subject: |
On my computer, this thread has run for 2 pages now with one my posts at the top of each. Odd as it seems, the only two of my posts that I can edit are the ones that are at the top of each page! Maybe you have to be the OP to get the edit button. Everyone should be able to edit all of their own posts... maybe with a time constraint of some kind.
Where does one find the option to view unanswered posts? I don't see it anywhere... or is that what you are asking me? If so, I guess that I wasn't much help. |
Larbo
Posted: Wed Dec 10, 2008 3:41 pm Post subject: |
The bottom of the forum page says
"You can edit your posts in this forum"
"You can delete your posts in this forum"
Not happening. Is there a webmaster link somewhere or is that something that Minnie or vtech must do? |
Posted: Wed Dec 10, 2008 3:43 pm Post subject: |
When you first log in you are on the Home/Forum selection page. Right upper quadrant. |
