Posted: Fri Jan 23, 2009 2:39 pm Post subject: |
Much info in manual, but it will answer questions about voltages and feedback. |
laluna
Posted: Sat Jan 24, 2009 9:06 pm Post subject: Yippee Iv'e found the fault! |
After I don't know how many hours of cursing and head scratching I have fixed my oscilloscope. It was the bridge rectifier for the +12 volt supply. All the other supply lines use the +12 volt line as a reference so if that goes faulty then all hell breaks loose. The lesson learned is don't suspect the worst. The buzzing in the high voltage CRT supply board was from the 50Hz signal going through the HV transformer. I changed the 10kV Cascade and the HV transformer unneccessarily at a cost of £65. I also suspected arcing in the CRT which would have meant the scrap heap.
Anyway, thanks to my two helpers on ESI, much appreciated.
Dan. |
laluna
Posted: Sun Mar 06, 2011 6:56 am Post subject: |
Follow up: I did manage to track down the fault after replacing the cascade and HV transformer at great expense. It was the bridge rectifier in the main LV DC supply All the buzzing and dotted trace was due to half wave rectified DC on the main supply lines. Cost, about 2 pounds sterling. Oh well!
Thanks for all the help and sorry it's late.
Dan. |
shivaki-stv2160 Philips • DVD-38 Rev 0 Harman Kardon • PSA Series Spectrum Analyzers -- Video O • 72845 tenma • B5X14A Philips • Service Bulletin DZ10-066-1 DENON • Eee Pad UM asus • Panel CHIMEI INNOLUX N140FGE-EA2 1 [DS] • pzt2907at1 ON Semiconductor • SB TOP MYSTERY •
