NathanMarks Guest
Posted: Sun Jun 19, 2005 6:08 pm Post subject: TV/Video Combination Machine Not Working |
So I put a video in and hit rewind, this is a TV/Video combo Machine.
The company is Symphonic.
When I hit rewind at one point i hit play to see where it was, then it conked out. Everytime I turned it back on it would just make a noise from the video machine area and then turn back off..
Then i dried spamming the eject button for the few seconds that it turns on for, but no use....
I don't know how to get it to work, it won't stay on! it makes a sound from the video machine for a few seconds and then it turns off. |
Posted: Thu Jun 23, 2005 5:14 pm Post subject: |
Hello friend,
Sounds like you need to service VIDEO.
Possible drive or loading belts broken.
Good luck
Sam |
tsgunnell
Posted: Thu Jun 23, 2005 10:51 pm Post subject: |
| you didn't say whether the tape was stuck in the machine if the problem is a broken belt or jammed machinism as another poster said the micro will shut down all functions |
zalds Guest
Posted: Thu Jun 23, 2005 11:30 pm Post subject: machine |
| if you up to it try this first make sure thier no problem in the mechanisim,belt or motor [like the drum or the capstan motor are working]then when if its good tru to put some oil on the timing swich if you can pullit out the better |
NathanMarks Guest
Posted: Sat Jun 25, 2005 12:33 am Post subject: |
| Yes the video is stuck in i can't take it out |
Al_Dodge_Bundy
Posted: Mon Jun 27, 2005 1:13 pm Post subject: |
Indeed sounds like a failing belt or pinch roller.
You can buy service kits for most vcr's and most of the times these rubber belts and rollers are easy to replace.
Most kits only cost a few Euro.
If the rubber on these belt and rolls aint weared out to much, you even can consider to clean them with some alcohol.
Good luck,
Mark |
Инструкция по эксплуатации NSX-S707 AI • PeepholeQ.mesa Sep78 xerox • pt100 dvdsvhs chassis tv d varianta 1 11 • [radial thru-hole] KLE08 Series Koolyn • Pioneer • DiamondMax 80 maxtor • lg 42lm3400-db ch.lt21c LG • TM2 Brochure May60 ampex • RZ-15LA66 LG • DM32X7000 Noblex •
