[email protected] Guest
Posted: Thu Jul 10, 2008 8:33 am Post subject: SMPS no power |
Currently, I am repairing SMPS(>1kW, 48VDC and 25A). I could not able to solve no power problem. I check almost every single components with a huntron tracker, of course, some certain component like mosfet driver IR2110, it would not able to check. Do you think it is the problem ? or something else. Pls help
Thanks |
miox_24
Posted: Thu Jul 10, 2008 5:26 pm Post subject: |
try finding out if thers a shunt regulator "TL431" its a 3 pin IC, replace this, it worked for me:) try to check also the zeners feeding the power transistors, it also worked for me on my other dead smp, now both are working fine tnx |
kulkarni Guest
Posted: Fri May 08, 2009 6:26 am Post subject: Computer power supply problem |
Dear sir,
I have a Intel PC - 945GZDMS-6H board. its have a power supply problem, some time when i am trying press the power button to start my PC, power LED flashing one time and quickly disconnected the supply.
when i tryed the same 5-6 times, then PC will be start by luck.
I cant understand, what the problem OR problem in SMPS of my Motherboard.
Pl suggest the solution about same.
Thanks. |
wozuiren
Posted: Sun May 10, 2009 10:03 am Post subject: |
My suggestion is to take out the SMPS from the computer, try to start it while loading it with a load of a 12V25W bulb (car headlight lamp) and see whether not it works. If the bulb is lighted up and the different dc output voltages are correct, then maybe you had a bad motherboard or a bad microprocessor. |
