jonathant83 Guest
Posted: Mon Sep 07, 2009 9:51 pm Post subject: Toshiba tz61v61 problems. |
tv shuts of, power light blinking. used to be able to unplug/replug and get it working but that does not work anymore. Opened up back of tv, pulled out power supply board(is on pastic stand. Also pulled out bottom board under it. Checked a few things with an ohm meter. everything checked good. Tried what was writen above, by unpluging plug marked with pin 8 "protect" Tv powers up but no lights on the front or anything on the screen. Pluged it back in, and just get 2 clicks. Sounds like that relay is kicking on, then kicking back off. Not to sure what else to try. Get get a tech out here to check it out, and truck is broke now, so can't bring it to im iether. any advise would be great. to nice to junk.
Jonathan |
jonathant83 Guest
Posted: Tue Sep 08, 2009 3:26 pm Post subject: |
| okay, pulled all the bottom boards that were bolted to the tray. Marked all the wires. and cleaned up the boards with some compressed air as they were pretty dusty. installed all boards temp, so i can connect wires to see if that helped. Tv started right up. Everything works as is should. But now all the guns are off (red and blue) and the middle of the screen looks like it's bowed in. Almost like looking into a concave mirror. Any sugestions?? |
std16ne06l-1 ST • PA-S2.200 Motronix • LN40S81BD LCD.part1 Samsung • CA-DW537 Aiwa • irg4bc20k International Rectifier • sfs9634 Fairchild Semiconductor • Ch3Specs Compaq-HP • CX65 Siemens • SGH-T108 Samsung • 09-npl3-layouts NOKIA •
