OldAudio Guest
Posted: Sun Sep 27, 2009 8:54 pm Post subject: Denon DRA-685 Remote Volume |
Hello,
I replaced the two 1 Ohm resistors in the +&- 15V lines as Mitch suggested and the "Protection" problem was solved, Thanks Mitch.
Now the volume control will not rotate when using the remote. The volume works fine if turned by hand, but not with the remote, however, the display changes in db as the remote volume buttons are pressed, therefore, the receiver is responding to the remote, and everything else on the remote is working. I checked for +&- 15V on the volume board and it is there, but there is no voltage at the volume up & volume down pins to ground when I use the remote. I have performed a reset (holding the tune up & down buttons when applying power) with no change on the remote volume problem.
Any help would be greatly appreciated!
Thanks,
Dave |
Posted: Tue Sep 29, 2009 1:58 am Post subject: |
| Back up to the driver IC and all the way to the microprocessor. You should be able to see some activity on the lines going to motor drive IC. |
Posted: Tue Sep 29, 2009 7:40 am Post subject: |
A defective motor itself could also cause.  _________________ You're over there, I'm over here. |
OldAudio Guest
Posted: Thu Oct 01, 2009 1:35 am Post subject: |
| Thanks for the info. I'll check out your suggestions and let you know what I find. |
Posted: Sun Oct 04, 2009 5:23 pm Post subject: |
I traced back to the input of the motor control IC (SIP #BA6209N) pins 5-6 and do not see a logic level voltage when using the remote. These are the input pins for the logic output directly from the microprocessor. I pulled the chip and checked for voltage output directly from the microprocessor when using the remote, and there is "0" volts. I am now assuming that the up/down output control portion of the microprocessor is open as it measures 25k to ground with power and/or signal on or off.
If there are no other possibilities, I'll probably sell it cheap with the understanding that the remote volume is not working, but everything else is fine. |
Posted: Tue Oct 06, 2009 2:09 am Post subject: |
| Anonymous wrote: |
Have to say that while it is always a possibility, it is rather odd for just two of the ports to be bad! Not sure of the 25K reading but it can't be open; if anything it is rather leaky/shorted. Just make sure it is not something on the trace or either connector ends.
Short of replacing the processor, Just about the only other thing would be a reset which I doubt will have any effect but worth trying. |
std16ne06l-1 ST • PA-S2.200 Motronix • LN40S81BD LCD.part1 Samsung • CA-DW537 Aiwa • irg4bc20k International Rectifier • sfs9634 Fairchild Semiconductor • Ch3Specs Compaq-HP • CX65 Siemens • SGH-T108 Samsung • 09-npl3-layouts NOKIA •
