sd Guest
Posted: Thu Aug 11, 2005 8:31 pm Post subject: Hitachi 50UX58B |
MY WAS WATCHING HITACHI MODEL 50UX58B AND IT WENT DEAD.
I CALLED HITACHI TV CO. THEY GAVE ME THEIR REPAIR SERVICE PHONE NUMBER. THEY CAME AND TOLD ME THAT FUSES ARE BAD AND NEED A NEW REGULATOR AND GAVE ME ROUGH ESTIMATE OF $ 250. HE WENT TO SHOP AND FAXED ME ESTIMATE OF $ 428.83. HE WROTE "IN DESCRIPTION OF WORK TO BE PERFORMED " NEEDS POWER SUPPLY REPAIRED. I ASKED HIM TO GIVE ME BETTER DETAIL SO I CAN COMPARE APPLE TO APPLE. HE SENT ME ANOTHER ESTIMATE AND TOLD ME THAT THEY HAD EXCATLY THE SAME TV NEEDED NEW POWER DEF PWB AND GAVE ME ESTIMATE OF $ 805.92 HOW CAN YOU TRUST THIS TECHNICIAN WHAT DO i DO ?
I ORDER THE BOOK AND FOUND OUT ( D940 B-120 SERVICE LED WAS OUT ANDD946 TV9V WOULD COME LITTLE BIT LATER.
i DO NOT KONW HOW TO PROCEED FROM HERE. CAN ANY BODY HELP ?
mark
Posted: Thu Aug 18, 2005 10:22 pm Post subject: |
is there a red led glowing, and are the green leds out?
if you have red and green leds which of the green ones is out? |
Posted: Fri Aug 19, 2005 6:37 pm Post subject: |
Dead - Replace c707 and e994
power light blinking fuse open Replace C707 (1000pF/2kv)
No power, power supply geen led light on then shuts off E994 protecter 2Amp open. C707 SHORT
No power Replaced open protector E994 and blown C707
A place to start. Sounds like c707 is shorted or dry. |
Hook 'Em In Texas Guest
Posted: Thu Sep 29, 2005 11:51 pm Post subject: C707 & E994 |
| After reading the posts on this site, I felt obligated to post. I ordered the service manual for my 50UX58B TV, found the C707 cap with a hole in it and smoke on the cap next to C707. I replaced C707 first and had the same LED power up symptoms as other posts (no B+ LED and flashing red service LED). Next I check the E994 and it was open. Replace it and the TV is operational again. I did both component replacement without removing the main power supply board. Just clipped the leads and soldered onto the exiting posts. Thanks for your posts. Saved me about $2,000. Gonna order a High Definition Tuner for this TV this week because I just found out that it handles 1080i input. Ahhhh!!!! Should have read the users manual a few years ago! |
guest Guest
Posted: Wed Nov 09, 2005 10:48 pm Post subject: c707 and e994 fuses |
| I have the same problem with my tv. I have been looking for these 2 fuses. can anyone please let me know where they are located? If i can change these myself, I'd love to try. |
nellinoggins Guest
Posted: Sat Dec 03, 2005 10:14 am Post subject: 1080i ?? |
Can the 50ux58B really handle 1080i? I know it says it has 1000 pixels vertical, but I cant get it to sync to any "i" modes?
Thanks |
LIU Guest
Posted: Wed Aug 02, 2006 1:04 pm Post subject: STK 392-110 |
MY HITACHI 50UX58B DEAD SECOND TIMES
First tims is 2 years ago ,C707 was broken .this time is 1 month ago ,I fine STK392-110 PIN 5 +18V ,PIN 4 only -4V and red LED flashing.Because I have not service manual , I do not know how to fix my TV, Can any body help? |
Posted: Fri Sep 07, 2007 11:08 pm Post subject: Help |
| where did you all find the parts at? |
[email protected] Guest
Posted: Mon Jul 14, 2008 5:03 pm Post subject: Dead Hitachi |
Same problem, and same simple fix. TV works great, as before. The shipping cost more than the parts!
Thanks for the posts. |
Posted: Mon Jul 14, 2008 10:17 pm Post subject: Re: Dead Hitachi |
| [email protected] wrote: |
