purcilas
Posted: Sat Nov 28, 2009 1:15 pm Post subject: 50PFP5332D Screen Issue/Repair |
Hi everybody,
Im new to this forum so hello!
I was attempting to fix my Phillips 50PFP5332D/37 plasma screen with parts from another one that I had laying around (thanks to phillips warranty service I got stuck with two bad tv's but atleast I got my money back).
So I "succesfully" fixed one of the TV's with components from the other but during the process I broke one of the flat cables that comes from the screen and I have one line on the TV that is dead, besides that everything works perfectly.
I would like to know, I have another screen that I could take this cable off from and replace it on the working screen but it looks like this is "glued" to the screen and no way to remove it. Am I correct? If it is I pretty much screwed myself because I learned later that the buffer board had no issues and I didn't even need to replace it and during the buffer board replacement is when I broke this cable I really think ill have to throw the TV away as the only solution will be to get a new screen which are really really expensive.
Thanks for your help in advance!
Here is a picture of what I broke.
Posted: Mon Nov 30, 2009 9:47 am Post subject: |
| unfortuanetly that ribbon is an integral part of the plasma panel and is not replaceable on its own. you will need to replace the complete PDP. |
purcilas
Posted: Tue Dec 01, 2009 3:02 am Post subject: |
Thanks for the reply gary. That's what I thought and it sucks I had another screen that is the same and I ripped off two ribbons to see if I could do something but it looks there is no way to put them back. It really sucks because this happened during the replacement of the buffer board which I later find out didnt need to be replace, if I didnt touch that I would of fixed the plasma completely
Might as well just buy a new TV set since the PDP is worth more probably than buying a new one. |
vmlinux Guest
Posted: Thu Oct 21, 2010 1:51 pm Post subject: Do you have the service manual for the TV? |
| Mine just started messing up on the hdmi inputs, and I want to see if there is a troubleshooting guide in the service manual so I can make sure i try and replace the right part. |
Posted: Thu Oct 21, 2010 11:17 pm Post subject: Re: Do you have the service manual for the TV? |
| vmlinux wrote: |
Did you try the firmware update first? |
V852UK Toshiba • Matsuki-Enesol (MPCAP-EneCAP) [SMD polym • RT-26LZ50 Service Manual LG • [radial thru-hole] GLR Series Zonkas • 2sc4919 Sanyo • [radial thru-hole] KRM Series Koshin • service Philips • pcp1208 Sanyo • Amilo A1630 - UNIWILL 258KA0 - 37UF3000- • Industrial All In One Touchscreen Comput •
