willip7 Guest
Posted: Mon Aug 22, 2005 9:52 pm Post subject: Philips 32pw6006 dead |
| just wondering if anyone has any idea about this problem. The set is completely dead - no power/standby LED, with just a very high pitched noise from the circuitry. When I removed the LOPT the power LED then comes on and flickers to show that it receives a signal from tyhe remote control (when any button is pressed on the remote). I thus assumed it was the LOPT causing a power problem and replaced it. However after a costly replacement the set is exactly as it was i.e no power LED, totally dead with just the high pitched noise. Any help/suggestions would be appreciated. |
Posted: Tue Aug 23, 2005 2:22 am Post subject: |
| First, what is a LOPT? ” Totally dead with just the high pitched noise.” Horizontal out put transistor sounds like it’s shorted. Transistor near the flyback. 61-280 PHILIPS 25”-27” HORIZONAL DRIVER REPAIR KIT FOR PHILIPS L01.1U TVS 5 p/c KIT ONLY $4.95ea. http://www.matelectronics.com/ Sounds to me like you need to get the kit. I know it’s a 32”. Start there. Not trying to be a sa, been there seen it. Mod’s, if you don’t want url’s posted let me know. Laid off and trying to help who I can! Payback! |
willip7 Guest
Posted: Tue Aug 23, 2005 6:32 am Post subject: |
| Thanks for that info. I'll give it a try. LOPT is the line output transformer or flyback as you call it. Cheers. |
JamesQB
Posted: Tue Aug 23, 2005 8:27 pm Post subject: |
I had the line-output transistor S/C (or HOT transistor), type BU2508DX, cause most likely being 47uF 25V electrolytic in the line driver stage.
If you replace the parts and get it working, it'll be interesting to know if you then suffer a further problem as I am - the set won't stay on for more than a few seconds (as per my post just put on here). Line stage shuts down. |
raf Guest
Posted: Sun Nov 05, 2006 2:35 am Post subject: |
| JamesQB wrote: |
are u sure u got the right trani isnt it suppose to be bu4508dx |
Poblizo.com : ïúòåøåñòâèÿ -
