42 philips 42pf5520d/10
mikecarey
PostPosted: Wed Feb 03, 2010 10:50 pm    Post subject: 42 philips 42pf5520d/10 Reply with quote
i have this set and with power to it and red light on, i turn it on, clicks tho its coming on, then clicks straight off, then no lights and seems dead, unplug n it wud do same process, psu is lj44-00101b
PostPosted: Thu Feb 04, 2010 12:38 am    Post subject: Reply with quote
Did you check the power supply for bulged caps?
mikecarey
PostPosted: Thu Feb 04, 2010 11:28 pm    Post subject: Reply with quote
yes no sign of them bulging
mikecarey
PostPosted: Sat Feb 06, 2010 10:46 pm    Post subject: Reply with quote
tried new psu,zsus,ysus and the board under the tuner board
eduard0476
PostPosted: Sun Feb 07, 2010 12:15 pm    Post subject: some tips for you!!! Reply with quote
first of all i would like to know your Unit.. this is CRT TV type or LCD TV? ok well'' if this is CRT type did you check B+ line Volts? 100vdc? did you check HOT mean horizontal output transistor. now cause of high voltage shutdown check t out B+ line when its goes up, this the cause of your hgh voltage shutdown means you have no seen light up to filament... and also check the E-capasitor has capasitance 100uf 160vdc and chec the risistor going to the B+ when its open... hope this can help. just update me sir
_________________
"TECHNICAL ANSWER!!!
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Sun Feb 07, 2010 2:55 pm    Post subject: Reply with quote
Google the units model number or zsus or ysus. Should find at least one hit that tells you what type of set (Plasma). Surprised
_________________
mikecarey
PostPosted: Mon Feb 08, 2010 8:09 pm    Post subject: Reply with quote
im only used to swapping the boards so am gonna sned it to local repairers
SPABSTER
PostPosted: Mon Mar 29, 2010 11:33 pm    Post subject: Re: some tips for you!!! Reply with quote
HI, my tv is running for about 40 mins, then seems to become hot and shutdown, it is a crt type, is this the same problem as you described in your post?
