wickenden Guest
Posted: Mon Sep 12, 2005 11:17 am Post subject: sony tv - white vertical lines in center |
i have a sony tv that when switched on there are two vertical white lines, aligned centrally.
HELP.
what can be done? |
psychojim40
Posted: Tue Sep 13, 2005 10:23 am Post subject: re |
| look vert ic volt. This ic can be the trouble |
Posted: Tue Sep 13, 2005 6:09 pm Post subject: Re: re |
| psychojim40 wrote: |
Correct. The vertical ic fails on sony's. If that doesn't fix it let us know. |
Posted: Wed Sep 14, 2005 10:00 am Post subject: |
| IF THE LINES ARE VERTICAL IE TOP TO BOTTOM THEN VERT STAGE IS OK AND FAULT IS IN LINE, UNUSUAL TO GET LINE FAULT AND TUBE TO BE LIT, CHECK FOR DRY JOINTS BETWEEN LOPTX AND SCAN COILS ESPECIALLY RIVETS WHERE LEADS ATTACH TO SCAN COILS THEMSELVES |
Posted: Thu Sep 15, 2005 2:13 am Post subject: |
| gary wrote: |
Vertical is left to right. Horizontal is top to bottom. Loss of vertical deflection is a compressed screen. Thin white line middle of the screen. From the left hand to the right hand. And it’s not “dry joint’s.” Cold solder joints. |
Posted: Thu Sep 15, 2005 5:49 am Post subject: |
| vertical scan failure results in a thin horizontal line ACROSS the screen ie left to right,you can prove this by removing the vertical output ic, a vertical line is a line fault as the scan is not being driven HORIZONTALLY ie left to right, AND IS A VERY RARE FAULT, |
mark
Posted: Mon Sep 19, 2005 8:47 pm Post subject: |
| Quote: |
| Vertical is left to right. Horizontal is top to bottom. |
THINK about that a minute......
I guess we all walk up and down walls, too. |
Posted: Tue Sep 20, 2005 12:37 am Post subject: |
| mark wrote: |
| Quote: |
Most people here haven’t gone to school for this. Yes it’s the opposite. This is how I describe it to people that don’t know. Knock your socks off describing it the right way. I thought people came here for help not grammar lessons. |
Posted: Tue Sep 20, 2005 12:44 am Post subject: |
| Sorry, wasn't signed in. |
