sharp geometry problem (pincushion)
carinik
PostPosted: Wed Sep 28, 2005 3:35 pm    Post subject: sharp geometry problem (pincushion) Reply with quote
Someone can help me, what's wrong with my TV, geometry was "blow up" (pinchusion problem). It's older model of Sharp. Eny idea?There is picture. Thanks guys. Mario
http://212.166.250.18:8080/mmcp/Controller;jsessionid=49F7C195C900C88C76A0ECED4B55E6F6?url=.;message-id=1018605001
carinik
PostPosted: Thu Sep 29, 2005 7:27 am    Post subject: picture Reply with quote
sorry...there is picture....
MARI
PostPosted: Fri Sep 30, 2005 4:39 am    Post subject: SHARP Reply with quote
HI MARIO
IVE GOT THE SAME NAME MYSELF,FIRST OF ALL WITH OLDER SHARP TV YOU WILL HAVE TO RESOLDER THE FLYBACK CAPACITORS IN THE LINE OP STAGE,THEY WILL BE DRY JOINED FOR SURE,ANOTHER PROBLEM YOU GET IS CORRUPTION OF THE EEPROM AND YOU WILL HAVE TO ENTER THE SERVICE MODE BY HOLDING THE VOLUME DOWN AND CHANNEL UP ON THE FRONT OF TV WHILE SWITCHING THE TV ON VIA THE ON/OFF SWITCH ,MOVE TO SERVICE MODE AND MOVE DOWN TO PIN CORECTION,YOU HAVE TO KNOW WHAT YOU ARE DOING OTHERWISE YOU WILL UPSET ALL SORTS OF SETTINGS AND END UP WITH REALLY BIG PROBLEMS,ALSO YOU WILL HAVE TO STORE EACH SETTING AFTER EACH ADJUSTMENT VIA THE REMOTE CONTROL,IT IS NOT AN EASY FIX IF YOU ARE NOT A QUILIFIED ENGINEER,GOOD LUCK IF YOU GO AHEAD,REGARDS MARIO. Cool
carinik
PostPosted: Mon Oct 03, 2005 7:12 am    Post subject: sharp geometry problem (pincushion) Reply with quote
Dear Mario,
I guess that "RESOLDER THE FLYBACK CAPACITORS IN THE LINE OP STAGE" means replacing burned capacitors with new ones. Am I correct? Before going so far, I was trying to enter into service mode as you described, but I couldn't. This means that turning on "TV BY HOLDING THE VOLUME DOWN AND CHANNEL UP ON THE FRONT OF TV" didn't cause any reaction. Any additional suggestion?
I am still considering if it is worth to enter into this reparition (price of capacitors and possible troubles with reparition - I am not qualified technician). Maybe is less trouble/money if I just buy a new TV.
Comments?
Electron Gr
PostPosted: Mon Oct 03, 2005 6:19 pm    Post subject: Reply with quote
Hi carnik,
This damage is not so serious,You can change the bad flyback capacitors but to do this need to have some skill about electronics. These capacitors are very cheap.You will need an iron and solder and a resoldering hand pump.
Be carefull with the capacitors polarity!!
My opinion is that you don't need to buy a new Tv set for this problem.
Regards
Peter - Greece
Electronic Engineer
PostPosted: Wed Oct 05, 2005 7:19 am    Post subject: Reply with quote
try to replace all the electrolytic capacitor near the pin amp transistor
le_onil123
PostPosted: Wed Oct 26, 2005 11:12 am    Post subject: asian goldstar tv problem Reply with quote
hi Im from the Philippines please help me on this tv problem of mine this is goldstar tv model no. CN-20A41G. the problem is that " the screen is almost dark with a small bright portion on the left side of the screen (approximately 1/8 portion of the screen)", the sound is perfectly clear and all tv channels are present,
thank you very much.
leony
