DJING_2004
Posted: Sat Apr 24, 2010 2:44 am Post subject: Hitachi Rear Projection Tv |
I Have A Hitachi Rear Projection Tv
Model # 65F59A
OK I Replace The DP6X Deflection Board On It because the first board on.it had an Open 3Amp pico Fuse on it bad the fuse is E947. its in the middel of the board the fuse is next to a Lcd Lit Green Light in the middel of board.. replace the pico 3amp
fuse and now the lit lcd green light go's on and off and the relay start's clicking on and off a lots of times....ok when i replace the second defection board the tv worked find
for about a week ....and now the second board when bad too.....it haves the same pico 3amp fuse bad on it to like the first board what is causing the 3 amp fuse to go bad help
the lit green lcd light is D905
Pico Fuse Is 3amp E947
Eddie
Thank u
[email protected] _________________ Eddie
Small Town Tv RepairMan |
Posted: Sun Apr 25, 2010 1:40 pm Post subject: |
| There's a kit, Deflection PWB Repair Kit X480315. It has you replace Q777 the H out, pico E947 and the heat sinks for the vertical IC and horizontal out put transistor. The main cause is the CRT's arching. I soldered up the heat sinks, and resilconed the 2nd anode leads. You can also replace them #H890411. |
payner pro music • M1400 Mackie • SR10119B LG • ctv-2012z, 2102z . Various • TK-2140-Addendum Kenwood • Panasonic TH-50PZ70E panasonic • ch1before Compaq-HP • Daewoo-Partsnic [radial thru-hole] RUH S • 3A1 Tektronix • 17TX220A Philips •
