djayha1
Posted: Fri May 21, 2010 8:19 pm Post subject: Hitachi 57" Rear Projection TV |
Model #57F500A
I thought it had the convergence problem, Ghost, Double images, color off, Ect. Well i replaced the STK IC's and a resistor, But that did not fix it. The color is still off , double images, But now it has a bowed image at top & bottom.... I tried to correct it with the auto (magic focus) and manually, after about 45 min.s of adjusting the color push the ini. change button and it goes blank for a few seconds and then the color grid pops back up all messed up again. Will not work at all (the changes) HELP!  |
Dan the Tv man Guest
Posted: Sat May 22, 2010 2:22 pm Post subject: Hitachi projection |
| Check the power supply and convergence board for bulged top capacitors.If none are found resolder the entire convergence board. |
Crowell
Posted: Fri Jun 04, 2010 11:15 pm Post subject: |
Hi djayha1.
Hmmm, by conversion board, do you mean the digital video board, because that’s the one in charge of converting all the analog signals to digital; so the 3LCD chip board can interpret them and create the picture on the screen trough the light engine. If I’m going too fast, then here is a post explaining about the 3LCD internal parts:
http://www.fixyourdlp.com/forum/viewtopic.php?f=4&t=1327
And here is another one that talks about the 3 colored chips.
http://www.fixyourdlp.com/forum/viewtopic.php?f=14&t=1279
In any case my first suggestion is that you check the digital board for any swollen capacitors, if nothing obvious. |
