kalo
Posted: Sat Jun 19, 2010 9:41 pm Post subject: SV5000W Disassembly; remove tape with dead power supply |
After 7 years w/o problems ) I got a dead unit SV5000w.
As discussed many times I will replace the caps in the power supply first.
Unfortunately I am stuck during the disassembly - I never opened a VRC before. To get the PCB out I need to remove the stuck tape first - I guess it covers a scew.
Is it possible to just provide power to the motor of the loading unit?
If yes, what voltage? Will it corrupt any adjustments?
Thank you in advance
kalo |
Posted: Sat Jun 19, 2010 11:51 pm Post subject: |
If you try that, be sure to disconnect motor from the motor drive circuitry.
Start with a few volts, increasing a volt at a time, by the time you hit 9 volts the motor should be turning. One polarity will turn motor in one direction, reverse polarity, the other way. _________________ You're over there, I'm over here. |
kalo
Posted: Sun Jun 20, 2010 10:42 am Post subject: |
Thank you for your reply.
"If you try that" sounds to me like "you shouldn't do that".
Is there a better way to get the tape out? |
