tftproblem1
Posted: Sat May 28, 2011 3:22 pm Post subject: Weird output from Acer 19" monitor, OSD works fine |
I don't really know how to describe what happened to my monitor, but I made a small video here: http://www.youtube.com/watch?v=Gjh5crE-Zx4
In summary, the output of the monitor is all garbled, but still there (not dead) - but the OSD works fine.
I have some knowledge of electronics - so I opened it up, checked the capacitors, didn't find anyone gone bad - but I'll check again, might have missed something (not very experienced in this).
Any pointers as to how could this happen, and where should I focus my investigation? I guess it's something related to the VGA input, but what could it be? (So I should check only the vga board, not the power one?)
[I already have another identical monitor which works fine, so making this work is not critical, nor do I care about the cost so much, I just wan't to see if I can fix it!] |
Posted: Sat May 28, 2011 10:22 pm Post subject: |
If signal is within specs, try re-seating LVDS cable ends. Otherwise scaler board. _________________ You're over there, I'm over here. |
tftproblem1
Posted: Mon May 30, 2011 7:55 pm Post subject: |
| jts1957 wrote: |
| If signal is within specs, try re-seating LVDS cable ends. Otherwise scaler board. |
The signal must be ok, since if i disconnect the vga cable and connect it to another monitor, all appears fine. I don't know if you mean something else.
I reseated the panel end of the LVDS cable, no changes there too. The other end is fixed on the scaler board.. So I'm left with the scaler board.
What should I check there? Could I replace the whole board (where can I find one on that case?) - Its an Acer AL1916W As monitor. I can easily find a power board but no luck with the scaler one :/.
The capasitors look fine on both boards, something weird is happening. I don't know what to check with a multimeter. |
manualst Philips • KVX2551D Sony • 2sc2412k sot-23-3l LGE • RL-40NZ60RB LG • OEM 715T2202 [SCH] . Various • esr70 datasheet en . Rare and Ancient Eq • b23nm60nd i23nm60nd f23nm60nd p23nm60 • DCR-SR87 SONY • 2sb1430 Inchange Semiconductor • CP-320 Daewoo •
