Viewsonic n2750w turns on for split second then goes bla
twobucks420
PostPosted: Sun Aug 07, 2011 12:49 am    Post subject: Viewsonic n2750w turns on for split second then goes bla Reply with quote
Hello all
I just recently had a viewsonic n2750w vs10576-1m have back light problems.
when i turn the TV on the screen appears in full color for a split second then goes to black (with no menus displaying) with audio still playing. I am suspecting the inverter board since the power supply all seems fine. The second problem i have is finding an inverter board. I have found a board that is close to what i have but a few numbers are different
my board is a Darfon 48.v0708.001 /E2 l270W1-24-V04 REV 1G
VO8807010104 G26 S163185 E206453 V070-001
proposed board Darfon 48.v0708.001 /E2 l270W1-24-V04 REV 1G VO8807010104 G34 S362143 E206453 V070-001
twobucks420
PostPosted: Sun Aug 07, 2011 12:53 am    Post subject: Reply with quote
DO you think the proposed inverter board will work with my TV or do you think i am out of luck?? The supplier does not list my tv as compatable.
here is the link
http://www.shopjimmy.com/tvs/darfon-v0-88070-101-backlight-inverter.htm
Thanks
PostPosted: Sun Aug 07, 2011 3:56 am    Post subject: Reply with quote
Don't forget, It can also be bad CCFL bulbs.
IF you have "power" and "backlite ON" voltages present, it could be defective Inverter board or bulb(s).
_________________
twobucks420
PostPosted: Sun Aug 07, 2011 4:17 am    Post subject: Reply with quote
well just to give u a little more information the TV started acting up about a week ago where in the morning the TV would turn on for an instant and then black out. I would then turn the TV off then back on and the tv would work no problem. Now its to the point where it just doesn't stay on. Do you still think that the bulbs could be the culprit if the entire screen lights up for an instant?
PostPosted: Sun Aug 07, 2011 7:02 pm    Post subject: Reply with quote
Look for burn holes in the transformers.
PostPosted: Mon Aug 08, 2011 2:11 am    Post subject: Reply with quote
Possibilities:
Bulbs (in LCD panel);
Fuse(s), Transformers, Electrolytic capacitors, driver transistor(s)/MOSFETS/ICs - ALL on the inverter board;
Inverter board NOT receiving continuous B-Plus (from the power supply);
Inverter board losing "ENABLE" voltage (usually from main board). Should be present when your screen lights and should still be present even after the screen goes out.
_________________
twobucks420
PostPosted: Wed Aug 10, 2011 12:13 am    Post subject: Reply with quote
ok i just used a cheap inverter and checked each ccfl. Each one lit up with no problems at all. I think this rules out the bulbs unless someone can tell me otherwise. I also ordered a new inverter board and should be arriving Thursday. I will keep you posted.
Thanks
twobucks420
PostPosted: Fri Aug 12, 2011 1:18 am    Post subject: Reply with quote
i just installed the inverter board and the TV seems to be working fine. I hope this fixed it for good.
Thanks for all the ideas
PostPosted: Fri Aug 12, 2011 4:17 am    Post subject: Reply with quote
Very Happy
