newone
Posted: Sat Dec 24, 2005 7:47 am Post subject: the best procedure to check ultra fast diode by analogmeter |
what is the best procedure?
how to know whith analog meter the diode is short or leckage |
Al_Dodge_Bundy
Posted: Wed Dec 28, 2005 11:20 pm Post subject: |
Can you measure resistance (Ohm) with your meter?
If so, a short should measure 0 - 10 Ohms
A good diode should measure infinitive resistance ( > 1000 M Ohms) in one direction and a few K Ohms in the other direction.
Grtz Mark |
awright
Joined: 10 Aug 2005 Posts: 20 Location: Oakland, California
Posted: Fri Dec 30, 2005 1:38 pm Post subject: Checking ultra fast diodes |
newone:
You can't check the SPEED of ultra-fast diodes with analog meters.
You can check forward/reverse conductivity to see if they are functioning basically like a diode, but that will tell you nothing about switching speed. You need a sampling 'scope to check rise and fall times.
Let us know if you are only trying to test for forward/reverse conductance or are trying to test for rise and fall times.
atwright |
[email protected] Guest
Posted: Sat Jan 07, 2006 12:57 pm Post subject: Re: the best procedure to check ultra fast diode by analogme |
| newone wrote: |
SET YOUR TESTER TO X10K ANY READING IN REVERSE SIMPLE MEANS LEAKAGES...OK? |
2630 RM-298 RM-299 SM l3l4 NOKIA • p31 Philips • RCD-590 Samsung • 22sc3914 2 • hfe s-dvr9sw service rrv3020 en Pionee • cdj-1000 212 Pioneer • 2sd879 Sanyo • STR-DB895D Sony • 101 107 Wavetek • ICFF11S, ICFF12S Sony •
