[email protected] Guest
Posted: Sat Dec 17, 2011 3:40 am Post subject: Sanyo Dp 42849 |
I have a Sanyo dp-42849 and it has sound but no picture the ccfl will flicker on but immediarely turn off .the audio remains on as well as all other functions.I have turned the set on in a darkened room but still no faint image. There are no swollen caps on the power supply module or the input circuit board. I suspect that the t-con is ok as I cam perform all other functions .I.E. channel change ,volume change. input change .What can I check next and can I check esr with a cheap dmm? if so how?any other tips or suggestions greatfully apppreciated.
Thank you,
Michael |
Posted: Fri Dec 23, 2011 4:39 am Post subject: |
| Sounds like the panel this is all I pull up Contact Sanyo Manufacturing Corp At 1-800-877-5032 |
Posted: Thu Jun 21, 2012 11:24 pm Post subject: Re: Sanyo Dp 42849 |
You need to replace the inverters. They are on each side of the tv. Master and slave
Before replacing them make sure the small smd fuses are good
jon
Electronic Surplus
| [email protected] wrote: |
Thank you,
Michael |
portege 3110ct TOSHIBA • satellite 2800 TOSHIBA • Z4814A-WW-1 MAKITA • Manual TX-NR414 En. gebr aanw ONKYO • AW1-12 RF261 140218 SERVICE MANUAL SCHEM • samsung ps42c430a1 chassis f71b Samsung • fdp10n60zu fdpf10n60zut Fairchild Semico • R1130H251B Pioneer • hfe denon dvd-558 1740 service DENON • Panel INNOLUX G156BGE-L01 0 [DS] . Vario •
