Posted: Tue Aug 12, 2008 8:05 pm Post subject: Hitachi C32W510SN-311. Sound, Blue Screen, FLyback Lines |
Hopefully the title says it all!
This TV has two faults, the screen has a blue tinge, with horizontal lines across the screen, about 1" apart. The picture is also slightly "pincushion" when you put it into 4:3 mode, and you can see the blue tinge extends beyond the picture about 1" each side.
This happens on both UHF and SCART.
The other problem is when the audio contains a lot of bass (not high volume, just bassy), there is a digital-sounding distortion, a squeak\pop sound. I've tried resoldering the audio amplifier already with no change. Pressing on the board seems to give a faint rustle as the board flexes.
Anyone got any ideas? Any help is welcome. |
Posted: Wed Aug 13, 2008 8:09 am Post subject: |
| set is fitted with a philips crt, 99% likely that it is the cause of the blue tinge and flyback lines, not worth replacing, volume problem, try replacing capacitors on output ic's supply rail. pincushion is probably just a case of slight adjustment in service mode but bear in mind you will not get it perfect as the e-w circuit in that set is not a "precision" circuit. |
Posted: Fri Aug 15, 2008 9:28 am Post subject: |
Thanks Gary.
It is indeed a philips CRT. If the blue + flyback can't be cured, there's no point in repairing. There's no fix for this that you know of?
(it's a nice TV, seems a shame to just bin it)
I'd managed to improve the pincushion a bit in service mode, but wasn't about to go nuts in there until the picture problem was fixed.
Cheers! |
Posted: Fri Aug 15, 2008 2:51 pm Post subject: |
| the only cure would be replacement of the crt, sorry, |
Posted: Fri Aug 15, 2008 3:05 pm Post subject: |
Ah well.
Coming to a skip near me soon...  |
dynax5 Minolta • ht-p1200 Samsung • SK50 rumble . Various • buk6607-75c Philips • bf556a Philips • TCK71 Sony • Схема DN-1800F DENON • bdx87 a b c Inchange Semiconductor • tv-1486 samwon • wistron je50-sb rsb schematics acer •
