bwallaces Guest
Posted: Thu Oct 30, 2008 10:27 pm Post subject: 19" PROSCAN LCD FLAT SCREEN TV |
| I HAVE A PROSCAN 19LA25Q TV AND IT WILL NOT POWER ON. ANY HELP FOR THIS TV? IT IS ONLY 9 MONTHS OLD. |
Posted: Thu Oct 30, 2008 10:40 pm Post subject: |
| Need a model number and the set should have a year warranty unless it's only 90 labor 1 year parts. |
foyle1 Guest
Posted: Sun Nov 02, 2008 2:33 pm Post subject: Proscan 19" flat screen |
I have the same problems. I bought 3 from K Mart, two are working fine after about 9 months, the other one's red light comes on for power, but when you try to turn it on, it wont turn green and power up?
Any suggestions? |
Posted: Sun Nov 02, 2008 2:35 pm Post subject: |
For the 2nd time:
Need a model number and the set should have a year warranty unless it's only 90 labor 1 year part _________________ Want To Fix Something?
http://www.manuals4you.com
http://www.justmanuals.com |
Posted: Sun Nov 02, 2008 4:12 pm Post subject: |
| Justmanuals wrote: |
For the 2nd time:
Need a model number and the set should have a year warranty unless it's only 90 labor 1 year part |
Posted: Sun Nov 02, 2008 6:09 pm Post subject: |
| This looks like the blind leading the blind here...... |
jsr9099 Guest
Posted: Fri Nov 21, 2008 6:25 am Post subject: |
| PROSCAN 19LA25Q is the product model >.< |
Rosemary NJ Guest
Posted: Thu Nov 27, 2008 1:35 am Post subject: Proscan Model 19LA25Q |
I have the same problem with my Proscan 19LA25Q with red light and willnot power on. I think it might be the power supply adapter non-functioning. Where can I get a new one? It is OUtput 12V 5A
Input 100-240 VAC 0.7 A MAX 47-63 HZ
Thanks |
Patnew Guest
Posted: Tue May 11, 2010 4:31 am Post subject: Proscan |
| I also have a Proscan Model # 19LA20Q that will not power up. There seems to be power going to the TV as you can hear a buzz / hum. mine is about 18 months old. |
Dan the Tv man Guest
Posted: Fri May 21, 2010 8:57 pm Post subject: Proscan |
| Check the power supply for bulged capacitor tops.The tops of the capacitors should be perfectly flat.Replace any that are not. |
