ksoehn Guest
Posted: Thu Dec 20, 2007 5:09 am Post subject: Television troubleshooting |
Sony KV-30HS510 30" HDTV CRT TV set (2003). No onscreen static charge or video-audio. Standby light blinks 6 or 7 times (depending on which time it is plugged in) hesitates, then repeats. There is a typical power up thrum when it is first plugged in. I have found sites which suggest low voltage of some kind precipitates such an indication. I have a multimeter but don't have a service manual, so don't know where to test for low voltage levels. I have found sites which suggest a control IC may be responsible, but don't know where to find it; is it a plug-in or solder-in chip? What would be the likely components, in order of cost, to try replacing for such a problem? Does anyone have a PDF of a service manual for this model? Sorry if I left out crucial model number, but I filled it and serial # elsewhere in the process and it may not have been posted. |
Posted: Fri Dec 21, 2007 1:12 am Post subject: |
This ones a pisser.
#A1302534A D board complete.
http://www.tritronicsinc.com/
It's easy enough, all you have to do is replace the board and set screen and focus.
Or search the net A-1302-351-A |
Frank Guest
Posted: Fri Dec 21, 2007 1:21 am Post subject: Re: Television troubleshooting |
ksoehn wrote: |
6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +B line is overloaded (A, B, M boards)
2. +B line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
Seven blinks means, "Horizontal Deflection Stopped" and there are no probable causes listed, its a protective action resulting form other problems,you may also check on D board,IC6501,IC8002,Flyback.C6532
These are starting points for qualified service technicians. |
Frank Guest
Posted: Fri Dec 21, 2007 1:54 am Post subject: |
[quote="minnie"]This ones a pisser.
Or search the net A-1302-351-A ,Minnie this part# also apllies to kv36hs500 D board,nothing wrong with it yet, but i'm preparing for the future,beside the set is 5 year old, got be ready, Thanks |
ALLYNC Guest
Posted: Fri Jul 10, 2009 10:12 pm Post subject: SYLVANIA 19C7-16 |
NO AUDIO: ADJUSTED T219 AND L221. ONLY STATIC AUDIO AND HUM
TOUCHED Y223 AND GOT A CLEAR RADIO STATION AUDIO :?: |
Posted: Fri Jul 10, 2009 10:18 pm Post subject: |
ALLYNC:
You need to start your own thread! |
ALLYNC Guest
Posted: Sat Jul 11, 2009 1:07 am Post subject: SYLVANIA 19C7-16 |
WHAT'S THAT SUPPOSE TO MEAN? |
Posted: Sat Jul 11, 2009 1:30 am Post subject: |
All posts above yours refer to a "Sony KV-30HS510 30" HDTV CRT TV set (2003)."
You are in the correct "Forum," (Equipment Repairs) but you should click on "New Topic" and then list your subject and message.
P.S. in some circles All Capital Letters equates to "SHOUTING!" |
Posted: Sun Jul 12, 2009 4:43 am Post subject: |
I USUALLY TYPE ALL OF MY TROUBLESHOOTING INQUIRIES IN CAPITAL LETTERS!
I DID GO TO NEW TOPIC AND IT SENT ME WHERE WE ARE TODAY!
IF THIS OFFENDS YOU, MY APOLOGIES! |
03-nhm4-syst NOKIA • 2sa2059 Toshiba • 999MK@ AIWA • pmbt3946ypn Philips • Panasonic NV-SD200 VCR Full panasonic • Описание DHT-683DVD DENON • Panel AUO B160HW02 V0 1 [DS] . Various • 2sk2417 Toshiba • 2sj185 NEC • aiwa hs-p08 hs-g08 hs-g500 sm AIWA •
