Vizio 52'' LCD stuck in "test mode"
vzohelp
PostPosted: Mon Jul 20, 2009 8:37 pm    Post subject: Vizio 52'' LCD stuck in "test mode" Reply with quote
My tv is stuck rotating from a "red, blue, and green" screen and I had a tech come out and he said that it appears to be stuck in factory "test mode." His recommendation is that either the board needs to be replaced or that entering a particular combination on the remote (code) might be able to pull the tv out of "test mode." Does anyone know if this sounds accurate and if so where I could find these codes to try and pull the tv out of test mode?
Thanks
Dan the TV man
PostPosted: Fri Jul 31, 2009 4:31 pm    Post subject: 52 lcd color rotation Reply with quote
Unplug the tv overnight,you cant put this tv in service mode with remote.If unplugging it doesnt work,you need a scaler board,
vzohelp
PostPosted: Sat Aug 01, 2009 2:14 am    Post subject: Reply with quote
I actually took the advice of the local repairman and replaced the mainboard myself and the tv still behaves exactly the same. so obviously, its not the main board. sorry, i did this before seeing the reply about the scalar board. just to clarify, the scalar board is just a different board? replacing the main board was pretty simple - just unscrew and replace, reconnect all the grounds and cables. should replacing the scalar board be this simple? also i assume that all lcd tvs have scalar board?
thanks
PostPosted: Sat Aug 01, 2009 3:33 am    Post subject: Reply with quote
thanks
A complete model # would help.
PostPosted: Sat Aug 01, 2009 3:12 pm    Post subject: Reply with quote
Vizio - VX52L-FHDTV10A
vzohelp
PostPosted: Fri Aug 14, 2009 3:47 pm    Post subject: Reply with quote
ok vizio told me that the "Test mode" i was referring to was actally called "burn-in" mode. before i try a scaler card, any other ideas why my tv would by stuck in "burn-in" mode, even after i have replaced the main board?
thanks
annakenna
PostPosted: Mon Sep 09, 2024 9:34 am    Post subject: Reply with quote
It sounds like the technician's assessment is accurate. Many TVs have a test mode that can sometimes be exited with a specific remote code. You can usually find these codes in the TV's user manual or by searching online for your TV model along with "test mode exit code." Good luck!
_________________
rice purity test
