ebr626 Guest
Posted: Tue Sep 29, 2009 1:00 pm Post subject: Sony KLV-S40A10E died |
All of a sudden my 40"LCD died. When pushing the standby button nothing happens. I checked the fuse on the power supply board but the fuse is OK. From the schematics i suspect a transistor that drives the relay coils (Q6400)
I didn't have the time until now to dive somewhat deeper into this, but before spending hours on measuring i decided to throw the question on the forum.
Thx
Edgar. |
Posted: Tue Sep 29, 2009 3:43 pm Post subject: |
check standby 5v supply which should be present all the time the set is connected to the mains, d6903 is notorious for going s/c and causing psu problems, check and replace ic6300, ph6300 and ic6301, the relays will not operate without the sby 5v being present |
ebr626 Guest
Posted: Wed Sep 30, 2009 5:56 am Post subject: Sony KLV-S40A10E died |
Gary, thanks for the reply. It might take a few days before i have the time again, but will get back with the results. |
ebr626 Guest
Posted: Fri Oct 02, 2009 9:09 pm Post subject: Sony KLV-S40A10E died |
5V is not present. I measured D6903 on the board and it gives reasonable readings (at least it's not shorted). I ordered a repair kit at ohmsuppliesco.uk. that has this diode, IC6300 and some other stuff. I couldn't find a replacement for PH6300 (PC123Y22JOOF) nor IC6301 (MM1431ATT), any ideas? |
Posted: Mon Oct 05, 2009 8:12 am Post subject: |
try chsinteractive.co.uk |
ebr626 Guest
Posted: Tue Oct 13, 2009 7:03 am Post subject: Sony KLV-S40A10E died |
IC6300 (switching regulator) was the problem. Thanks to Gary for pointing me into the right direction. |
