viewsonic 32in lcd tv power supply broken
Goto page Previous  1, 2, 3 ... 16, 17, 18 ... 24, 25, 26  Next
tada
PostPosted: Sun May 30, 2010 7:22 pm    Post subject: connector pins for fsp212-3f01 Reply with quote
This is taken from the fsp212-3f02.pdf. Warning this is not exactly the same as 3f01 but it seems to match based on my cold measurements. . I put ? where I can not corraborate.
CNS1 PINOUT
1-4 gnd
5-6 +12v? Does not show any voltage if power is off. At least on my deffective TV Smile
7-9 +5v? This will be on even if your remove the board from tv and connect it separately to the AC
10 5v standby Power on -OFF . Does anybody know how to turn power on with a board removend from the TV? Would a 2.2 Kohm resistr from 5+ will turn on the 12 and 24 Volts supply?
11 to CNS2 pin 9 probably pwm input for inverter
12 to CNS2 pin 10 probably pwm input for inverter
CNS2 PINOUT
1-4 gnd
5-8 +24v to inverter? Does not show any voltage if power is off.At least on my deffective TV Smile
9 to CNS1 pin 11 probably pwm input for inverter
10 to CNS1 pin 12 probably pwm input for inverter
Does anybody know what to measure to verify the power supply module needs replacing? I would not want to order a new one for nothing even if i'm pretty sure it is it Smile
Cheers and thanks for help,
Adrian[/img]
bustitup
PostPosted: Wed Jun 30, 2010 4:56 pm    Post subject: back cover Reply with quote
I have a N3250W and want to replace the power supply....I know this sounds dumb but how do I get to it?....I see no access panel
I had the same problem as Chris350
please help
bustitup
PostPosted: Wed Jun 30, 2010 5:00 pm    Post subject: Re: back cover Reply with quote
please help
it was not chris350 it was Roger Ellingson
PostPosted: Wed Jun 30, 2010 6:09 pm    Post subject: Reply with quote
Remove the rear cover - the back off the TV?
_________________
PostPosted: Wed Jun 30, 2010 6:17 pm    Post subject: Reply with quote
Yes.......there are screws on the right but none on the left on my model
PostPosted: Wed Jun 30, 2010 6:36 pm    Post subject: Reply with quote
I thought you read this whole thread... COUPLE of pages back:
nj12nets wrote:
my issue is disassembling the lcd. I've removed the screws and located the slats on the tv but even when I attempt loosen the clips and try to separate the back from the front it won't come off. I saw someone say about standing the tv up, then getting the clips, and slowly working the panel off but I didn';t seem to make any progress. Any time I would start trying to unclip one side the other side would pop back into place. Are there any tips or suggestions sfor this? The tv is only 2 years old but If I can get it open I can try diagnosing the components or ordering a replacement board. Any tips?
AND
I feel better now, I was able to finally get the case off, I wasn't prying enough inbetween the panels.
_________________
bustitup
PostPosted: Wed Jun 30, 2010 8:05 pm    Post subject: Reply with quote
thanks man I missed it
AND
train123
PostPosted: Tue Jul 06, 2010 2:43 am    Post subject: FSP212-3F01 low voltage on 12 volt line & 24 volt line Reply with quote
I accidentally posted an new post so here it is again on the correct topic.
I have a 32" Viewsonic with sound but no picture. The power supply is a FSP212-3F01 and the typical output caps were bulging so I replace all of them. 5 volts is fine but when I measure the others, 12 volts is reading 2.8 volts and 24 volts is reading 10 volts. I even tried replacing IC1 (L6598D) but no change. Any ideas what to check next?
train123
PostPosted: Tue Jul 06, 2010 3:41 am    Post subject: Reply with quote
I did some more work and found the 4.8 volt "on" signal from connector CNS1-pin 12 is zero but when I lift the jumper going to QS3 the 4.8 volts return. I couldn't find QS3 or QS1 shorted but I'm not really sure how that circuit works.
PostPosted: Tue Jul 06, 2010 3:44 am    Post subject: Reply with quote
I got 2 n3250w tv. I fixed the power supply of the one that didnt turn on at all. I replaced the diode and shorted transistor and it works perfectly.
The other one turns on but turns off on its own and cycles randomly like that. I replaced the transistor in case it was faulty.
Then I probed and found I have a a good 5v coming from the ps. And the other 2 pins which get 5volts to turn on the power supply drops when the tv turns off on its own. I lose the 12 volt on the tv when it happens.
My question is : Can I actificially put 5 volts on the 2 turn-on signals ( i believe they are) or does it need something more elaborated to keep the power supply on?
Page 17 of 26
