techboy1000
Posted: Tue Sep 07, 2010 7:54 pm Post subject: Need help with LG 42PC3DVA-UD |
I have the above model and it has sound but absolutely no picture. Has anyone encountered this problem and how did you fix it?
If I could get an idea where I should be focusing my attention, it would save me a lot of time. Thanks. |
Posted: Wed Sep 08, 2010 3:24 am Post subject: |
No smeared video or nothing? Does the panel light when you turn it on? |
techboy1000
Posted: Wed Sep 08, 2010 4:21 pm Post subject: |
minnie wrote: |
No. Nothing. The screen remains the same when I power up as it is when I turn it off. As for the panel, if you mean the light to indicate that the power is on, yes. It is red when off and turns green when I turn the set on. |
Posted: Wed Sep 08, 2010 11:14 pm Post subject: |
Did you check the caps on the power supply? Check the VS and VA voltage? |
techboy1000
Posted: Thu Sep 09, 2010 2:58 am Post subject: |
minnie wrote: |
I looked over the circuit boards for obvious damage and found nothing. However, I checked all the ceramic fuses I could find and one 4A-250V fuse on the YSUS board was open. Trouble is, I don't know if it blew because it may have been weak or if something caused it to blow.
All I did for caps check was inspect for bulging tops. I know that's not very reliable, but the caps on the power supply look fine. If anything, those on the YSUS board do look slightly bulged in comparison, but I'd have to remove it to test them and that will be a job in itself. |
Posted: Thu Sep 09, 2010 3:12 am Post subject: |
Y sustain blow all the time... There should be a part number on the board. |
techboy1000
Posted: Thu Sep 09, 2010 7:03 am Post subject: |
minnie wrote: |
Do you mean a part number for the whole board? Are you suggesting replacing the whole board? |
Posted: Thu Sep 09, 2010 10:13 pm Post subject: |
techboy1000 wrote: |
minnie wrote: |
Welcome to my world. Yes the whole board. |
techboy1000
Posted: Thu Sep 09, 2010 11:17 pm Post subject: |
Found the part number. It's 6871QYH048B. Now what? How much does it cost to replace one of these boards? Hope you have a good source where I can buy one. lol |
