vip Guest
Posted: Sat Mar 12, 2005 6:02 pm Post subject: Philips 42PF9952 Plasma TV. Goes into standby after 1 sec. |
Please help, I have a Philips Plasma TV, Model: 42PF9952 /39s.
When the TV is turned on, you get sound and picture for about 1 second and then it goes into standby, and the green light goes to orange and flashes.
I think it may be a power supply problem maybe a faulty capacitor???
Does any one know exactly what problem could be and if it is simple to fix or how much should I expect to pay to get it repaired.
cheers! |
dave12 Guest
Posted: Wed Feb 15, 2006 6:05 pm Post subject: 42PF9952/39S |
Hi, i am also trying to repair this plasma screen,
The power board has a few components that have blown and in turn has blown the track clean off the board, i have replaced all of the components apart from 3 diodes which have cracked so now i am unable to identify them, i dont suppose if i give you the board reference numbers (Numbers next to the components) you would be able to tell me what it says on the actual diodes?
Thanks, David |
Posted: Wed Feb 15, 2006 8:30 pm Post subject: |
| LET ME KNOW CIRCUIT REFERENCES AND I WILL TELL YOU WHAT THE DIODES ARE. |
amit Guest
Posted: Wed Jul 26, 2006 5:24 pm Post subject: Re: Philips 42PF9952 Plasma TV. Goes into standby after 1 se |
| vip wrote: |
cheers! |
hello sir i got the same problem did you fix your problem yet and maybe you know what has to be replace or where i can buy the whole board ? |
Posted: Wed Aug 16, 2006 6:49 pm Post subject: Re: Philips 42PF9952 Plasma TV. Goes into standby after 1 se |
| vip wrote: |
cheers! |
Hi guys, i have the same TV and it has started doing this, "ie" go,s into standby!! How did you fix it....... |
mgb299 Guest
Posted: Tue Aug 05, 2008 11:13 pm Post subject: plasma broken |
| I say: Throw it away |
jbeaaaa Guest
Posted: Fri Jan 09, 2009 6:11 am Post subject: i will take them off of your hands!!! |
| if you are unable to fix these TV i Will gladly take them off of your hands, and dispose of them. e_mail me at [email protected] |
busa Guest
Posted: Wed Dec 30, 2009 5:50 am Post subject: Philips lcd tv's |
| Of course He'll by them cause he knows the fix ... I had luck fixing one of these Philips 42" lcd's tv .... it was 6 bad capacitors on the main power supply board ... e-mail me for help .... [email protected] |
