mahmoudesm Guest
Posted: Fri Jan 07, 2011 8:55 pm Post subject: vestel 11ak30 standby problem |
| i have vestel tv chasis 11ak30 ,it has processor st92195c3b1,and stv2246h .The problem is Standby state.power led is red .Bu808 is ok ,6n80 power suply mosfet is ok.i replaced st92195 .when i open pin 47 of syscon IC TV turn on what are other possibilties.... any one to guide me .thanks in advance. |
Posted: Sat Jan 08, 2011 4:44 pm Post subject: |
Does the LED stay solid red when you attempt to turn it on, or does it start flickering?
Try:
Check D800 - BA159 for short circuit
Replace D806 (it may read ok) |
Posted: Sat Jan 08, 2011 4:51 pm Post subject: |
| Oh, and eeprom 24C08 may be the problem. Might need reprogramming or replacing. |
mahmoudesm
Posted: Sun Jan 09, 2011 7:32 am Post subject: |
hi,thanks,i try chek it and go back,
yes led is flickering and i hear a sound like that chik..chik .chik! |
Posted: Sun Jan 09, 2011 4:41 pm Post subject: |
Another thing to check on 12V line is:
D810 (UF5402) in the PSU might be short-circuit. |
mahmoudesm
Posted: Sun Jan 09, 2011 7:05 pm Post subject: |
I replaced D800,D806,optocopler: IC 801,C623 :33mf/160v,C826: 47mf/160v,c822,c856,c812 but TV is in standby stat still.
when I conect R118 to ground TV turn on and power led stay green.
also voltage of Drain pin of Mosfet Q801 is unstable (27v...110v).
Voltage of D808(Katod pin) is 11.5v. |
Posted: Tue Jan 11, 2011 8:21 pm Post subject: |
i found problem.i replaced C827: 4700uf/16V .
this cpacitor was not short-cicuit but it was leaked. |
Posted: Fri Jan 14, 2011 3:37 pm Post subject: |
| mahmoudesm wrote: |
hello.
C613=10UF -50V near horizantal driver must replce.
zamani |
