ivtec
Posted: Mon Jun 13, 2011 11:40 pm Post subject: sony KV36S42 dead |
Hi guys my Sony was on and suddenly went dead,the power led blinks continuously any help would be apreciated,. |
Posted: Tue Jun 14, 2011 12:48 am Post subject: |
Check for open .1 ohm resistor and bad MX0841.
Check HOUT transistor for shorts and HDRIVER transFormer for bad joints. _________________ You're over there, I'm over here. |
Posted: Tue Jun 14, 2011 2:34 am Post subject: |
Thanks jts1957 i apreciate i'll check all that , |
ivtec
Posted: Tue Jun 14, 2011 4:32 pm Post subject: |
jts1957 wrote: |
Check HOUT transistor for shorts and HDRIVER transFormer for bad joints. |
I have changed the H Output transistor that was bad it still doent fire up but it won't blow the transistor that i replaced and the led continuous blinks without stop i also resoldered H Output Transformer,any other component that i should change can you please specify the .1ohm resistor ? thanks in advance. |
Posted: Tue Jun 14, 2011 5:47 pm Post subject: |
Resolder pins of Horizontal DRIVER transfomer. Other parts in Main power supply (IC601/R607) _________________ You're over there, I'm over here. |
ivtec
Posted: Wed Jun 15, 2011 12:28 am Post subject: |
jts1957 wrote: |
Resolder pins of Horizontal DRIVER transfomer. Other parts in Main power supply (IC601/R607) |
Thanks bro your're right on the money i apreciate. replaced ic601 and r607 and C5148 H.O.T. and also resolder H.O.T. evrything's fine again.apreciate |
