Ronnie Guest
Posted: Sat Mar 18, 2006 6:48 am Post subject: 24PW6006 A10E chassis Goes into stby |
Any help apreciated i have a A10E chassis comes on for 15 seconds with picture then shuts down but power supply still running when turned on from standby stays on longer maybe 2-3 minutes then shuts down again service menu shows error 5 and 11 done a few checks and cant see anything running hot. {error 5 is reserved } |
Posted: Sat Mar 18, 2006 4:14 pm Post subject: Re: 24PW6006 A10E chassis Goes into stby |
Hello,
It is probably the picture tube or the software on the microboard.
If you see discolaration when you have picture it is certainly the tube.
These tubes ( ESF, ECK types ) are really the worst types ever made!
Here in Holland Philips had to give 4 years warranty on the tube, because of the complaints!
Greetings
Jeroen Hartman |
ronnie Guest
Posted: Tue Mar 21, 2006 1:27 am Post subject: |
can't see any discolaration on screen but is there any way to test microboard or tube. obviously tv won't fire up without line drive or without the CRT board. i am just about ready to give up on it since i have spent so much time on it. |
Posted: Tue Mar 21, 2006 5:18 pm Post subject: |
first thing to check is what the model and chassis are, according to my philips data base the model you list is a LO1.1E chassis, if it is an LO1 this is a very common fault caused by incorrectly adjusted A1 voltage, try advancing the screen voltage very slightly, may have to repeat a few times till set will stay on, the correct way to set this voltage is complicated and the set doesnt stay on long enough to do it anyway!!!!! |
2sa1261 NO • 201T1SB00 ET-SB-EX-SI 1265607411 Philips • Epson LQ-670 Service Manual epson • 2n3055 UTC • 2n4921 2n4922 2n4923 Inchange Semiconduc • panasonic th-49ex600x chassis km32 panas • 2sk2731 1-5 Rohm • index.php p=manualbrowser&l=first&s=down • CS2-1 compressor Yerasov • hp pavilion ZE4900 HP •
