marinsirakov
Posted: Fri Sep 07, 2018 6:59 am Post subject: radio code for audio nissan pp9940 h |
Hello dear,
My original radio brake and i found another to replace. The new one is model Nissan PP-9949-H. It fits OK and also the cable jacks are OK. The problem is that when i switch it on it shows - - - - . No one key is active ...
I want to ask how can activate the menu to put the code in. Also can yo please generate me code?
the model is: cl0344w0001729
part n is: 286-8177-51
I will be very helpful because there isn't any information about this radio model - it is old but I still drive my Terrano.
Thanks ! |
tmcu
Posted: Fri Sep 07, 2018 7:19 am Post subject: Re: radio code for audio nissan pp9940 h |
| marinsirakov wrote: |
Hello dear,
Thanks ! |
We can only help with clarion if it has an extra sticker with a number like
C70000001234 , unfortunately not all clarion's have this ! |
marinsirakov
Posted: Fri Sep 07, 2018 8:07 am Post subject: |
Unfortunately I don't see any additional sticker.
At least can you advice me how can I get to the menu I will be in order to set the code |
marinsirakov
Posted: Fri Sep 07, 2018 8:10 am Post subject: |
| I find in a website this d78014gc726 if is usefull |
tmcu
Posted: Fri Sep 07, 2018 12:43 pm Post subject: |
This reference is the cpu used in it I think , the code entry instructions seem
very simple and don't mention a menu ?
https://www.radio-code.co.uk/PP9940H-Nissan-code-entry-guide
Your radio is locked out through incorrect code entry attempts , so you need to leave it turned on continuously until it resets , it can be several hours depending on the number of incorrect attempts. |
marinsirakov
Posted: Fri Sep 07, 2018 1:34 pm Post subject: |
Unfortunately Clarion codes are currently unavailable on this website. Can you advice me any other code generator ?
Will be thankful
[/img] |
tmcu
Posted: Fri Sep 07, 2018 3:52 pm Post subject: |
Will be thankful
[/img] |
Having considered this again when you don't know the history of this radio I think it may be better to get it recoded by a local recoding service ,otherwise you may pay for the original code from an online service only to find it doesn't work because the radio has been recoded previously !
You should find a local recoding service by a search ( google ? ) online or maybe a radio repair shop ! |
marinsirakov
Posted: Sat Sep 08, 2018 5:50 pm Post subject: |
| Anyway, today i left tue radio switched on and after 3 hours it went to the code menu. Can you advice me any number code to try. It mught work properly, if now I will go to radio specialist. In the region I life they are not too much. I afraid the result will be same as if i try unstable code... |
tmcu
Posted: Sun Sep 09, 2018 7:49 am Post subject: |
If you try too many incorrect codes it will lock up for good , I think its best to try to find a specialist now to read the code for you ! Good luck ! |
marinsirakov
Posted: Tue Sep 18, 2018 6:58 am Post subject: |
| I went to the technical and he told me that he dont know how to decode it. There is a micro chip but he cant supply same, so maybe still the best way is if anybody can help me with a hack code. I should pay for it. Otherwise I need another audio. The problem is that this audio is easy to be connected with the CD changer ... If anybody can help me I will be very pleased ! |
