JodiMae Guest
Posted: Thu Jun 15, 2006 1:41 pm Post subject: Toshiba help please! blinking light |
I have a toshiba TP50F50/TP50F51 which has a red light on the front that just blinks. When you plug it in it makes a ticking noise as though the tubes are comming on, there is no picture/no sound. Just a little red light blinking.
Is this a dead set? |
davidpemsb
Posted: Thu Jun 15, 2006 3:14 pm Post subject: |
Hello,
Your TV must be at protect mode,try replace vertical IC &Horizontal output transistor.
I think this might help you. |
fongs Guest
Posted: Thu Jun 15, 2006 4:12 pm Post subject: |
Hi there,
Your TV's SMPS is doing a power cycling ie. It trys to power up & switch itself off due to component failure. Its doing it over & over again that's why u hear the ticking sound.
Could be HOT or SMPS problem... Vert problem unlikely to cause this symptom. Can be tricky & unsafe to fix if u don't have TV troubleshooting skills. |
Posted: Sun Jun 20, 2010 7:49 pm Post subject: Re: Toshiba help please! blinking light |
JodiMae wrote: |
Hi there the common problème with the blinking red led is the convergence IC (2) p/n stk392-110 witch are quite large IC located on aluminum heat sink but after replacing these parts you may have to realign
convergence. |
Posted: Sun Jun 20, 2010 8:49 pm Post subject: |
They've been waiting (patiently) all these many years for that solution. _________________ You're over there, I'm over here. |
KH UE100 equalizer . Various • sc3 frnt panasonic • XR-P170 P270[1].part08 Pioneer • KV-28FX60A Sony • 565POWERPCB LG • ctv575,577,578 Clatronic,Bomann • spb07n60s5 rev.2.3 Infineon • VER0.9 2DIN-AV SCH01 MYSTERY • hfe cd-9g service en Casio • 5990-8737EN N7602B Signal Studio for 3GP •
