cheesebox Guest
Posted: Wed Jun 21, 2006 7:52 pm Post subject: Blaupunkt Lausanne CD31 - switches off at medium-high volume |
The unit works fine at low (<30) volume. Above 30, the sound stutters and cuts out, and the unit either "reboots" or switches off. It's worse with bass turned up above zero setting. At higher volumes I noticed the display dims in time with bass sounds. I've had the same problem with it installed in two different cars, and on an AC/DC adapter. Visually all components look fine.
Is this a known problem, or one anyone might be able to suggest the cause?
Thanks in advance! |
Posted: Fri Jun 23, 2006 11:36 pm Post subject: |
| I don't know, but if you have made good connections on the outside of the unit I would be checking on the connections inside of the unit. (solderjoints) What do the waveshapes look like? |
HTS326112 SB-EX-SI 1369050453 Philips • Prology MDD-710T Prolodgy • 5992-0190EN Transmission Lines and Refle • clevo d400s d410s Clevo • nv-gs11 panasonic • City Boy 100 Grundig • p1110 Dell • KV-1435M3 SONY • GTA40 Yerasov • [snap-in] LP5 Series Elna •
