racing.fire
Posted: Mon Jul 17, 2006 12:05 pm Post subject: Problem with Samsung PCL545R Rear-Projection CRT |
I have the TV described above. 2 days ago, the TV showed the red, blue, and green separately on the left side, but as you got towards the right, the colors got closer until they correctly lined up at the edge. One day later, the TV just turned off. While it's plugged in, it makes a whiring sound, which seems to be coming from a big capacitor on the power supply, and it will click (like it's turning on) and click again after a few seconds (like it's turning off) and it repeats a few more seconds later. It stays in this circle and nothing happens. No display, no sound. Nothing.
Also, the power button doesn't do anything. It starts that cycle upon plug in.
So before this gets thrown out...is there a way to fix it?
Thanks,
Kevin K. |
racing.fire
Posted: Tue Jul 18, 2006 5:32 am Post subject: |
bump
Any ideas anyone? |
Posted: Fri Aug 11, 2006 4:55 am Post subject: |
Hi there
The clicking/whirring you hear is from the power supply trying to ramp up to operating voltage & turning off again when it overloads because one of the components on the power supply circuit is knackered.
I'd unplug it & leave it off for a day or so then get the back off & check the circuit board for anything which looks burned out - it'll most likely be a capacitor short circuiting to ground
Change the burned out component & you'll be sorted
Make sure you use an insulated screwdriver/ rubber gloves / extreme care |
Posted: Fri Aug 11, 2006 6:05 am Post subject: |
| The problem with it is the same as with 90% of all projos that die. The convergence outputs are whacked. They are loading down the power supply. |
Guest2 Guest
Posted: Fri Aug 11, 2006 12:29 pm Post subject: simliar problem |
Hi there:
I have the 5415R TV which I suspect to be a simliar model, and I have almost the same problem!
I hear the click, then the power stays on, except you see nothing, and the controler & the buttons don't work. anyone has any idea? |
Posted: Sat Aug 12, 2006 12:41 am Post subject: |
| change stk-392-040 |
mch6336 Sanyo • aspire 7730, 7730g series service guide • techabst NOKIA • Cakewalk Sonar Twelvetone • Zeck-A200 400 amp . Various • blf6g20-75 blf6g20ls-75 Philips • HP Jetdirect Print Server 70X User Guide • [smd] EK Series Evercon • quanta zl2 rf schematics acer • ET-2190A EVGO •
