leafar Guest
Posted: Thu Sep 14, 2006 4:24 pm Post subject: phillips tv totally dead |
i have a phillips tv model29 pt8321/7r found out a shorted diode inside,any other idea what`s the reason why the diode was busted? |
Posted: Thu Sep 14, 2006 7:53 pm Post subject: |
WHICH DIODE????? |
leafar Guest
Posted: Fri Sep 15, 2006 9:47 am Post subject: |
the only biggest diode inside the board with markings of SB306 . |
leafar Guest
Posted: Fri Sep 15, 2006 10:43 am Post subject: |
I`m afraid to turn on again the TV after i replaced the diode bec. I knew that there was a reason why the diode got busted. |
Posted: Mon Sep 18, 2006 10:47 am Post subject: |
If you don't know enough about the tv to understand the fundamentals of the power supply, you probably shouldn't try and fix it yourself. These things can be dangerous. |
leafar Guest
Posted: Mon Sep 18, 2006 11:07 am Post subject: |
thank you for your info,i have already check another shorted part transistor type diode -p5nb60 pf. after i replaced it and turned on the tv and it works. |
Adjustment Item List Minolta • bss138 Fairchild Semiconductor • EL2531 Philips • hfe onkyo tx-18 service ONKYO • AVR-1312 DHT-1312XP.part3 DENON • [polymer smd] PVH Series Elna • hfe dra-635r 835r 1035r service en DEN • RPI-3B-V1 2-SCHEMATIC-REDUCED RPi • 24sgS3-pc0 Philips • 500S Intek •
