claudem
Posted: Sat Nov 04, 2006 1:25 am Post subject: re green background on sony kv32xbr96s |
Thanks anyway Carcus for your help but useless for my problem,sorry to tell you that but your helpfull comments were dedicated to the previous
post for Todd Wallace ! sony xbr 5 blinking post on sun oct 29 4;12pm
hoping not to offend you knowing your expertise ill will be thankfull for your opignon solving my problem or steps to get rid of greenish background.
regards
Claude Marineau (claudem) |
carcus
Posted: Sat Nov 04, 2006 6:34 am Post subject: |
no worries you have not offended me
it all still applied in you case because you said :-
Quote: |
led blinks none stop for 3 minutes with sound but no picture then picture comes back on for few seconds |
you will prob find that the led is not blinking non stop and there is a very short pause so it could be "5 blinks with a very short pause then 5 blinks and so on for 3 minutes" or say "9 blinks with a very short pause then 9 blinks and so on for 3 minutes" but you do have to watch very closely ....
see if you can count them .... did you try teletext while you have no picture ?
also you can try tapping the neck of the CRT with the handle of a screwdriver while the set is running to see if there is any change.....
Best of luck |
carcus
Posted: Sat Nov 04, 2006 6:55 am Post subject: |
and it is worth checking the resistors on the tube base PCB incase any have gone high resistance or open circuit ... also look very closely with a magnifier incase any of the high value carbon type resistors have cracks in them especialy where the G2 / Screen voltage is fed in and goes through to the G2 pin on the CRT .....
Best of luck |
Fran
Posted: Sat Nov 04, 2006 7:19 pm Post subject: SOny |
May you need to use degaussing coil try first to unplug the from the household outlet wait a couple minutes plugg again , if does't work you maybe have check the digauss circuit don't have sckematic can't give more for now also see if have no motor. speakers,florescent lights that have starters near the set . |
claudem
Posted: Sat Nov 04, 2006 9:40 pm Post subject: Re: SOny |
Fran wrote: |
thanks fran: degussing circuit is perfect all colors at there places (hearing the boing noise on powerup)
Carcus :teletex is not working when screen is blank while red led is blinking none stop without any pause until pictures come on. except the green is over (reduced gcut to from 8 to 3 ) all colors perfect except every thing thats is black is mixed with fainth green ,i think the 1k protection see something wrong with picture and kills crt .
example: when listening a dvd movie in 16/9 format the top and bottom of screen is suppose to be black? mine is dim green and if i use teletex is bright green. |
carcus
Posted: Sun Nov 05, 2006 7:23 am Post subject: |
ok what so what i would do now to isolate wether its the video circuit or the crt is swap the green with say the red ..... so i would disconnect the green cathode by unsoldering the link or resistor that usualy leads to the green cathode pin on the tube base socket and the red also then using 2 peices of wire connect the output from the red to the green and the output from the green to the red .... if you then get a red tinted background you have a video fault and if you still get a green tinted background you have a crt fault .............. |
claudem
Posted: Sun Nov 05, 2006 7:12 pm Post subject: re sony |
carcus wrote: |
hi carcus did wath you said interchange green with red at the input of crt pcb board :still have green tinted background
any solution to reduce the effect? not planning to replace crt.
thanks again |
carcus
Posted: Mon Nov 06, 2006 6:17 am Post subject: |
well not really claudem ... you can try reducing the G cutoff a little more and you could try adjusting the screen/ G2 control on the flyback but to be honest these things usualy only get worse and you may start to get other issues also since what you will find is the crt has prob got a leakage between the green cathode and the heater or the grid .... all sorts of issues can occur from this later..... |
claudem
Posted: Tue Nov 07, 2006 1:27 am Post subject: |
carcus wrote: |
thank-you for your help,played with g2 and gcut manage to get pretty good picture. |
