slide 17 Guest
Posted: Wed Nov 01, 2006 2:34 am Post subject: sony kv35v36 |
have sony kv35v36 and the picture went out then came back now its small static lines in middle but sound works fine someone told me to change resistor r536 will it help or what else to do |
Posted: Fri Nov 03, 2006 4:26 am Post subject: |
Solder up or replace the verticle IC. |
dolescle
Posted: Wed Nov 08, 2006 11:46 am Post subject: |
I'll back up minnie's post..solder it.. |
noori
Posted: Wed Nov 08, 2006 2:27 pm Post subject: |
Dear Friend, check Video out put transisitor collector volt(i.e 180 volt) emitting from the fly back.
And change the capacitor 22uf 250 volt it is on the 180volt supply. |
indian tiger Guest
Posted: Thu Nov 30, 2006 10:28 pm Post subject: kv35v36 tv |
check the smps power supply, if you have an osciloscope check any voltage spikes in there, and any fluctuation in the voltage to the collector of the fly back transistor, check the damper diodes on the collector of this transistor, and the fly back capacitors arround there.
i will be soon
Indian tiger |
Posted: Thu Nov 30, 2006 10:40 pm Post subject: kv35v36 |
The SMPS power supply is very delicate and critical in this sony cercuit. first of all take out the power supply disconnect from the main board and digaussing coil and connect to mains. (be careful each time you discharge the main smoothin capacitor after turn off power and do working). check the B+ voltage, if any fluctuations suspect first the zener diode in the board that between B+ and -ve. check the smoothing capacitor also.
if both are good check the recifire diode (bridge) .U could use 4 individul diodes (high voltage high efficiancy 3 amp,600v will get may be in radio shack) ones to replace this,recifires could be bad all times...
i will be soon
Indian tiger |
[radial thru-hole] ES Series Elite • fqd12n20l fqu12n20l Fairchild Semiconduc • 2sd608 Inchange Semiconductor • 3139-248-80591-130-2 Philips • KEH-P8600R,P7600 Pioneer • AGC-52xx Daewoo • Panel CHIMEI INNOLUX V470H2-LH4 1 [DS] . • hfe pioneer a-09 service CREST • • HiFi M19-C M29-C Grundig •
