Posted: Thu Mar 01, 2007 7:51 pm Post subject: SONY KV-28CL10U |
HI ALL, I HAVE ONE OF THESE SETS WHICH TURNS ON FROM STANDBY BUT NO PICTURE OR SOUND, I FOUND 3 BURNT RESISTORS THEY ARE R5046 R5068 R5056 THEY ARE IN THE LINE STAGE. HAS ANYONE HAD TROUBLE WITH THESE BEFORE? I CANT TELL IF THERE BLOWN AS CANT READ THE VALUE OF THEM. CAN ANYONE GIVE ME ANY TIPS? I ALSO NEED THE VALUES OF THESE RESISTORS AND MAYBE A CIRCUIT DIAGRAM?? THANKS IN ADVANCE, JON. |
Posted: Fri Mar 02, 2007 9:22 am Post subject: |
r5056 is 680r, r5046 is 820r and r5068 is 680r all at 3w. they burn up because when the set is placed in standby all rails other than the 135v are turned off, to prevent this recuring replace smd resistor r6019 on the base of q6001 with a 1k resistor, after replacement when set is placed in standby 135v rail will also be turned off. |
Posted: Fri Mar 02, 2007 5:59 pm Post subject: |
thanks for your help gary. |
Posted: Fri Mar 02, 2007 8:04 pm Post subject: |
gary wrote: |
gary have checked the values of these and they are ok, so any ideas of futher problems?? they have got very hot but still reed fine. although they were very dry jointed, reflowing them made no diffrence. |
Posted: Mon Mar 05, 2007 9:09 am Post subject: |
how many times does the led flash? |
Posted: Sat Mar 10, 2007 7:35 pm Post subject: |
hi gary, managed to get it to kind of work in the end, replaced above resistors, found R5048 o/c. i think this is 3.3 ohms. (looks to be orange, orange, silver, silver) tryed it then found the scan coil plug was loose and arced, this caused ev5033, which is a by228 to go s/c. i replaced this and the set worked but the east west is now faulty. any ideas?? sorry to pick your brains so much but im a young enginner just coming into the trade. i guess it could be a corrupt eeprom, seeing as it was full of dry joints. thanks for your help and pateince, jon. |
Posted: Sat Mar 10, 2007 10:16 pm Post subject: |
Gary, I'm from the US. Pm me what east/west means. |
Posted: Sat Mar 10, 2007 11:45 pm Post subject: |
hi minnie, e/w means east/west, its the geometry of the picture, with an east west fault usally the picture is pin cushion or tarpezum. i hope this helps your understanding, jon. |
Posted: Mon Mar 12, 2007 1:05 pm Post subject: |
try chs for a diagram |
Posted: Mon Mar 12, 2007 2:38 pm Post subject: |
ORANGE, ORANGE SILVER SILVER IS .33R, CHECK R5048, R5053 AND Q5032, HAD TROUBLE WITH ALL THOSE CAUSING E-W ERRORS |
3700 GETTING STARTED Dell • av28wh3 JVC • 8111A HP • Pilot U385 PILOT (US) • 8031FV3E Minolta • AO4726L TOSHIBA • HP 33120A Service Guide Agilent • 24gs3-p02 Philips • HS-4 AH GREBE • 22DC21300 SB-ET-EX-SI 4791553963 Philips •
