jp_poolplayer Guest
Posted: Mon Apr 23, 2007 4:34 am Post subject: Sony KP-53S75 Convergence? |
1. First the set was dead
2. I replaced the Power Supply board and was able to power up successfully.
3. But now the convergence is out of wak, expecially the green.
4. I cannot bring it into allignment via service mode using the cross hatch pattern and remote control adjustments.
Is this normal after replacing the PS Board? Any ideas on what to adjust?
Thanks ahead of time |
cory Guest
Posted: Mon Apr 23, 2007 11:55 am Post subject: |
| replace 2 convergence ics.(STKS ON HEAT SINCS).DONT FORGET HEATSINC COMPOUND AND CHECK PICO FUSES. |
jp_poolplayer Guest
Posted: Mon Apr 23, 2007 5:46 pm Post subject: re: |
| I am a little confused. Dont these reside ON the power supply board, which I just replaced?? |
cory Guest
Posted: Tue Apr 24, 2007 12:12 am Post subject: |
| i think the power supply board is separate.these ics i believe are on the deflection pcb,with the flyback on it. verify by checking the board you replaced,look for 2 large ics starting with stk392-???.if you dont see them check on deflection pcb.near the rear of the board. |
jp_poolplayer Guest
Posted: Tue Apr 24, 2007 12:41 am Post subject: |
| Yep, they are definately on the G Board (Power supply board). |
Posted: Tue Apr 24, 2007 10:02 pm Post subject: |
| Did you swap the digital convergence generator? Or is that on a different board. |
09885-90050 9831A Oper Feb77 HP • MS-14VN Funai • JBL • GF-9696 Sharp • CUC2600 - 2800 Grundig • [radial thru-hole] LW Series Chang • 5991-0401EN Model Quality Assurance (MQA • schpower panasonic • STK8050 Sanyo • C20-1641-1 Core Requirements for 1130 FO •
