RCA TV turns off after 5-10 minutes
skips1969
PostPosted: Wed May 16, 2007 12:42 pm    Post subject: RCA TV turns off after 5-10 minutes Reply with quote
It is turning itself off after 5-10 minutes of use. Can be re-started, but same thing continues. It's probably a 25" set, manufactured in June 1998, and is model# F25211BC. Was wondering if there was a common part going bad that would cause this and deciding if cost worthy to repair, or just replace.
Thanks
Frank
PostPosted: Thu May 17, 2007 7:06 pm    Post subject: Reply with quote
What Chassis#?
cory
PostPosted: Thu May 17, 2007 11:01 pm    Post subject: Reply with quote
check solder connections on verticsl ic,horizontal drive transformer and if it has it l14401 in horizontal circuit.
PostPosted: Tue May 22, 2007 12:19 pm    Post subject: Reply with quote
So, there wouldn't be a common switch or something "plug-n-play" that goes out on these (frequently) that needs replaced? I haven't opened it up yet to clean and check soldered connections, was just curious if this was common on older TV's, RCA's in general, etc....
Thanks
PostPosted: Fri Jun 15, 2007 12:36 am    Post subject: Reply with quote
Chassis is CTC 185. Comon problem on this chassis are bad solder joints on L4401. It is located between Q4401 and T4301.
PostPosted: Fri Jun 15, 2007 4:15 am    Post subject: Reply with quote
L14401
jijaju
PostPosted: Fri Jun 15, 2007 5:17 am    Post subject: service manual for zenith/pvr6069dt Reply with quote
im working on this rear projection tv,the problem is it has a pin cushion on the top and the bottom of the screen,the convergence is mis align and i cant enter the service mode because there's no character so i cant even open the menu.
brianjagielski
PostPosted: Sun Jun 17, 2007 12:00 am    Post subject: Re: RCA TV turns off after 5-10 minutes Reply with quote
I had an RCA 36" TV from the same month and year that had exactly the same problem. After 3-4 weeks of it shutting itself off, one day it just stopped turning on and it was dead.
PostPosted: Sun Jun 17, 2007 6:12 pm    Post subject: Re: RCA TV turns off after 5-10 minutes Reply with quote
L14401 has bad solder connections and it probably took out the horizontal output transistor.
