Electronic Oil Gauge
ganck
PostPosted: Fri Sep 14, 2007 9:18 am    Post subject: Electronic Oil Gauge Reply with quote
I am electronic newbie and has general knowledge in electronics component and microcontroller.
I have an old Nissan Sunny car which the oil gauge is not functioning and I could not find a new for replacement. I am thinking of develop a LED display to indicate the oil level to replace the faulty gauge.
My idea is use one LED to represent a level of oil, i.e. if I have 2 LEDs on, it means I have 2 level of oil left in the tank.
I know how the typical oil gauge works, the detector is using resistant, with the change of resistant, the amount of current flow to the gauge is changed and that change the gauge pointer.
I read that LM3915 can be used to control the LED behavior which base on the input of the current to this controller. Can someone kindly show me how to do this?
Thank you so much.
_________________
~~ Danny Gan ~~
PostPosted: Fri Sep 14, 2007 11:17 pm    Post subject: Reply with quote
Why not buy a after market oil gauge?
ganck
PostPosted: Sat Sep 15, 2007 3:10 pm    Post subject: Reply with quote
My car was manufactured in 1985. I tried few mechanic shops around my area but couldn't find one, not even a second hand. Pretty old car, not a single manufacturer here in Malaysia produce that. I just like this car and want to maintain it as the other parts create no problem.
_________________
~~ Danny Gan ~~
PostPosted: Sat Sep 15, 2007 5:36 pm    Post subject: Reply with quote
http://www.breakeryard.com/cars/make/Nissan/Sunny.aspx
wolfdogg
PostPosted: Mon Oct 01, 2007 9:04 pm    Post subject: Reply with quote
you can replace the oil pressure or temperature sending unit, and send the signal to a new oil pressure guage as suggested, or is it oil temperature? this can be done to any car. also, theres alot of threaded "plugs" on engines, ayou might check to see if one of those plugs is in the oil chamber that runs thru the motor,l where you can place an alternate sending unit there (universal threads so anyone can be adapred to screw in here from an autoparts dealer)
and something my own dad always tells me, GET THE REPAIR MANUAL for the car, it will always help you. the manual may contain a place where you can connect a sending unit. Personally i think its alot of work to repair that faulty circuit which is probably just an "idiot" light, where a guage will be much more accurate and reliable.
i never heard of a "level" guage for oil, just a pressure warning indicating either your starting you car in sub-zero arctic and had better warm up the oil before starting the car, (doubtful) or that your already too low on oil. An oil pressure guage is usually just for reassurance and tells if you lost your oil pan on the freeway which means your already screwed anyway.
i would opt for a replacement guage mounted somewhere under teh dash, with a RED "idiot light" led to scream bright if teh pressure drops to dangerous levels.
_________________
Rusty Electronic Tech;
been thru electronic engineering in college, top of class grades, 10 years ago. some field exp.
